However I have daily non-matches like the following:
/movies/Modo Avião (2020)/Modo Avião (2020) WEBDL-1080p.mkv
No match with Plex Movie, however when selecting TMDB under match options I get a correct match “Airplane Mode - tt5617916” btw don’t watch that movie.
I have ~70 movies in my catalogue which all need manual TMDB matching. A few more examples:
/movies/Most Likely to Succeed (2019)/Most Likely to Succeed (2019) WEBDL-1080p.mkv
/movies/Cyber Bride (2019)/Cyber Bride (2019) WEBDL-1080p.mkv
I’ve done “the plex dance” and checked naming. Expected behaviour would be that Plex Movie automatically searches TMDB for matches as well as its other sources.
Both match correctly for me without “WEBDL-1080p” in the file name:
/movies/Most Likely to Succeed (2019)/Most Likely to Succeed (2019).mkv
/movies/Cyber Bride (2019)/Cyber Bride (2019).mkv
I renamed Modo Avião to Airplane Mode and it matched correctly.
/movies/Airplane Mode (2020)/Airplane Mode (2020).mkv
In the Also Known As section in the imdb.com listing, the worldwide movie title is Airplane Mode.
Try it for one or two and see if it makes a difference.
If there is any extraneous info you want to keep in the folder or file name, put it in square brackets and Plex will ignore it. Ex: movie_name (year) [stuff_to_ignore].ext
If you need to rename many files, look at filebot, https://www.filebot.net/. Many people use it to quickly rename multiple files.
Indeed I’ve just done the same to Radarrs profile.
The catalogue is what some might call large, so it’s going to take a few more hours for Radarr to finish renaming. I’ll post back once plex recovers from the renamed files
Renamed files as above, did “plex dance” again (god I hate that name). Rescanned and rebuilt library. I’m missing metadata for 308 out of ~7500 movies now which is more than before. I’m rescanning metadata for those 308 items again to give it another chance.
The three previously mentioned movies are still all missing metadata:
/movies/Modo Avião (2020)/Modo Avião (2020).mkv
