Anybody ever have this happen, The names are smeared together. And my scan circle is offset. When I ad new movies they appear with names blurred smeared, Then they disappear outta the list. Click on a Tv show, When you come back to main server screen they will not appear again till you scan the folder. Then they appear with smeared names. Few days like this it’s killing me. Plex Media Server Logs_2021-12-12_17-49-30.zip (6.9 MB)
Ok I did that all, even restore my pc to a previous point. All the same. Then I checked plex on 3 diff smart tv’s and 2 pc’s all the same won’t keep the last few movies loaded and they have the names smeared together. Any other ideas??? Seems to deff be in the plex synology server if it is on all.
Ok so It’s still shows the issue.
I have a synolgy 1520+
How do I completly delete all servers from the Synolgy “I mean every singly piece of plex data” All servers and start fresh new server and reload 80tb of media.
Gonna just go fresh. Start fresh New everything
no, because of the first post here.
but i just double check, maybe it’s because of display resolution.
My surface Pro runs Display setting at 200%
when setting Chrome to 90% or less, everything is ok
