Hi having the same issue since Wednesday too can’t use my Plexamp outside from home tried everything forward my router port too no luck very frustrating miss my music while I drive . What do I need to do got life time pass too if possible @OttoKerner help will be amazing
[mod edit: none of your servers’ certificates are affected.]
[mod edit: your server’s certificate is not affected. Ensure that you are not using custom domain names; the certificate is not valid for these. i.e. “Custom server access URLs” must not contain anything.]
My remote stopped working for couples days ago. Can anyone check if it’s affected?
[mod edit: your cert was renewed automatically on 29th of March. I recommend you to take a look at the Plex data folder and inspect the locally stored copy of the cert file. It should have a file date after the cert renewal. Verify it has proper access permissions for Plex server. Maybe stop and restart both server and clients, to ensure they all get the new cert.
Please open your own forum thread for any followup reports and questions.]
So i think i fixed the error, Hoping this works for everyone else
I went to settings, network and saw Preferred network interface was set to “Any”
So just setting this to my server ip it instantly fixed any remote access issues.
Hope this helps
Mobile app stopped working for me too. I restarted the server and the physical computer I checked the settings states it’s available remotely but not working.
Im having an issue too, I updated plex and now the remote access doesn’t work. Strangely if I change the port to default 32400 it claims it works which isnt possible as I dont port forward that, and if I try to connect then it doesnt work. Anyone happen to experience the same issue?
I’m thinking this is an issue on Plex’s end. Too many people updating and restarting their servers at the same time so registration is failing.
I pulled/recreated the container and remote access worked at first, now it is not working even when the server says it should be reachable. Verified the port is open via UPnP.
Edit2: just extra info. I restarted Plex, then restarted server (even though local was working), then restarted router\gateway and modem. Checked traffic and dns checks and all were okay. Nothing made a change. Then suddenly, after digging around Plex forums and Reddit and downdetector to see if it was just me… it started working again with no change on my side so… I’m happy to chalk it up to a backbone\service hiccup.
