Plex remote access issues - cannot connect securely
This is also occurring for me I believe.
Get this error on the webpage when trying to access: app.plex.tv is unable to connect to “Media Server - Odin” securely
Its “Secure connections” setting may be set to disabled, or you may need to adjust some settings on your network.
Server log shows the same error as Nails1226’s post above mine.
[mod edit: Please stop and restart your server now.]
After several hours of TS my network and speaking with my ISP, I believe I’m also having this issue as I see the cert error in my logs.
I think this is also happening to me. I ahve done everything and nothing works. Server gpes online for 10 sec then offline again, have used plex for many years and this has never happend befor
[mod edit: your server’s certificate is valid and healthy.]
Hi, I am also having this issue after manually deleting an expired cert that would not renew automatically. Tried waiting an hour and still getting 429 Rate Limit Exceeded.
May 16, 2026 19:34:54.202 [140408294099768] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
  <error code="1003" message="API rate limit exceeded" status="429"/>
</errors>
Would appreciate assistance. Thanks in advanced!
[user edit: Works now. Thanks OttoKerner!]
I am experiencing the same issue my logs show the same issues with Failed to upload CSR: 429 and API rate limit. I am attempted to manually delete the expired cert with no success.
May 17, 2026 09:36:35.412 [133691984403256] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
[user edit: Working now. Thank you.]
I am having the same issue as OP. I have verified i am not on CGNAT, have an open port, no vpn, server ip is reserved. I can not access on any devices using the app on wifi or cellular. I can still access on the direct web link or via the windows app if I allow for unsecure connections.
When i retry manual port forwarding on the plex settings it says my server can be accessed externally until i click off of that menu, then it goes back to saying it failed.
[User edit: that worked, thank you!]
Is this still an issue? My server stopped allowing remote access today. Sitll works on local IP. Any help is greatly appreciated.
Hello, I have the same problem with my certificate. I opened the port directly, but remote access still won’t work.
Checking in to see if you can check my certificate as well. Thanks for your help!
[mod edit: your server’s certificate is valid and well. Whatever your issue is, it has nothing to do with the cert.]
[user edit: Thanks!]
I’m having issues as well, can you check me too
May 19, 2026 00:37:38.490 [20612] WARN - [HttpClient/HCl#29] HTTP error requesting GET https://****.dae2fb7c725345049ea45057e9d899eb.plex.direct:32400/identity (60, SSL peer certificate or SSH remote key was not OK) (SSL certificate problem: certificate has expired)
You might want to edit your post to redact/obfuscate the public IP address in the URL you shared (the 4 dash-separated digits).
I have stopped and restarted my server multiple times over the course of this past weekend, including just a few minutes ago. I can access the server through the web app through Firefox, not Chrome, but I still can’t access the server through the mobile/tablet apps, my TV app or anywhere else to be honest. This has been an issue for me since Saturday May 16th, 2026 and Starting and stopping it has not fixed it. Any further guidance would be greatly appreciated.
My streaming devices and mobile apps can no longer access my Plex server either. Works fine in the browser. I do have 429 errors in my logs.
Think Im having the same issue. seeing error 429 in my logs like others.
Good to go. Thanks.
I am receiving the same error. I have restarted the server, enabled port forwarding and set up a static IP. Plex is available on the local network but not external. Remote access is green ticked, but goes to red if secure connections are required.
Working, thank you
I am on the same boat, restarted server. Worked up until a few weeks ago.
I am having the same issue, connects sporadically then disconnects. Can someone please check my certificate?
I just started experiencing remote access issues. I’m seeing “alert certificate unknown” in my server log after attemption to access the server from my mobile app.
Can you please check my certificate?
