Plex remote access issues - cannot connect securely
Could you please reset mine as well
[mod edit] Not affected
Hi, could you check to see if I also was affected by the certificate issue? Im having the same problem.
Could you please check and see if I was affected by this certificate issue as well?
I’ve experienced these issues over the past few days.
Is there anything I can do on my own?
Can you check me as well, please?
[mod edit] Not affected by this issue.
Also mine if it’s not a big ask. I’ve been struggling with this since yesterday. I’m getting this in my logs: ”ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429”
It seems that I am having the same issue since at least yesterday, anything I could do or do I just have to wait for a certificate check? Or do I have a different issue?
Having the same issue
Nov 22, 2025 11:47:06.869 [22421180951352] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
@OttoKerner hey, did you check mine?
Sorry if you just didn’t get around to it yet!
Update: Working for me now.
Could you please check mine as well? I am having the same issue.
You are not affected by this particular issue.
Could you have a look at mine as well? I am having some strange remote connection issues and I am trying to rule stuff out.
To everyone who posted in here so far, and who didn’t restart their servers yet:
Please stop and restart your Plex servers.
Not everyone is affected though. I’ve responded or edited the original post for users who are not affected. Restarting their server cannot hurt, but probably won’t help with whateveer issue they are dealing.
Could you check my certificate please? I got the same issue
Did you check mine as well? I restarted my server a few times and tried claiming it again but it’s still not working and I still have the “CERT: Error acquiring new certificate: Failed to upload CSR: 429” error
Sorry, yours did fall through the cracks.
Stop and restart your server now. No reclaiming necessary.
Hi Otto, could you check mine? For me also non of the apps are working since yesterday all of a sudden, on the server itself everything works fine.
The certificate for your server hasn’t been generated yet.
I’m not sure if it has to do with the fact that your server has 2 network adapters in the same network. Better disable one of them.
Thank you so much for the mega quick reply. I’ve disabled the second adapter and rebooted the server, is it now possible again to generate the certificate?
