Plex remote access issues - cannot connect securely
It should be fine now. Reboot again.
Thanks for checking!
apps and webpage weren’t working internally due to it being an insecure connection for some reason which made me think it was a cert issue, but externally streaming was working fine. I had tried rebooting the host and restarting the container and neither fixed it. Works this morning now after changing nothing so :man_shrugging:t3:
Yessss it works again! Thank you so much! My girlfriend is overjoyed also hahaha.
Did you get a chance to check mine? my remote access is green and my port is open, but devices outside my network are unable to find the server. I definitely saw a CSR 429 error like some of the others here
Yes. Stop and restart your server, please.
Please look into mine as well
:folded_hands: Thanks a ton. I was losing my mind last night. felt the imposter syndrome kicking in lol
Im having the same issue as described. Is it possible you could check my certificate?
You are not affected by this particular issue.
Noted
@OttoKerner can you check mine? Was able to spin up a new server and it worked, but my main server broke.
thanks!
Done.
Ottokerner can you check mine as well please Many Thanks
Hello, I have the same problem with one of my two servers.
Please
thanks
Done. Please stop and restart your server.
yipeeeeee
4 hours on this problem thanks thanks
Have a good evening
Otto, forgive me for repeating this same issue again but Im not getting what this issue is and do not understand what your advice is “restart server”. I believe I have, also reinstalled PMS. What am I missing? After a few minutes I get again lose outside connection.
I rolled back version and it worked for a day or more then lost it again.
