Plex remote access issues - cannot connect securely
The topic of this thread is problems with security certificates not getting refreshed, when they’re expired.
As far as I can see, your servers are not affected by this.
Hello,
I’m having the same issue. Is it possible to check if I’m affected by the SSL problem? Thanks!
Yes. Stop and restart your server, please.
I am having the same issue.
Thanks.
You are not affected by this particular issue.
Please don’t hijack this thread.
Is my server/account affected by this issue? Everything worked fine and dandy and then boom; already restarted the server and checked my local network configuration – not that I’m trying to fix the wrong stuff here right now. Thanks!
Indeed you are. Stop and restart your server now, please.
Can you check if I am affected? Thanks
This can only affect servers which are at least 3 months old.
Hi, I think I’m having the same issue
Done. Please stop and restart your server.
Could I have my server checked as well? I’m not sure if my issue is the same, but I’m getting a bunch of CERT errors since yesterday or the day before.
Done.
Could you please check mine.. Getting cert expired errors in the log
I already did that. Please stop and restart your server.
Hello - mine has stopped working as well.
Done. As above.
Not having issues with my servers (S2Nice) but my niece prolly needs a check (cbost0), as she and her hubs can’t even get to it from LAN anymore. I have logged into unraid and it’s up, login to “local” plex via tailscale works, oddly enough.
I even had them instal ts to a firecube and that streams just fine. I knew it was network/security, but just hadn’t wrapped my head around it
Indeed. Tell them to stop and restart their server.
