I’m also having this issue, it started yesterday after a password reset. Is there a way to check this too?
You are not affected by this particular issue.
To all users who were told that they are not affected:
If the issue is restricted to the Plex Web app, chances are that you are actually affected by a new security feature of the Firefox and Chrome browsers. See Important note about Chrome and Firefox Local Network Access
I am having same issue, can my revoke my cert as well
My is stuck and seems to be a cert issuer
Hello, can you please check mine too?
It seems I have the same issue. please help
I hate to say this but I’m having the same issue… please help… and I am not using chrome or firefox…
Please stop and restart your server.
It doesn’t look like you are affected by this particular issue.
Please stop and restart your server now.
I am having the same issue. Are you able to check my certificate as well?
Best wishes
Done. Please stop and restart Plex server.
Thanks a lot. Everything is fine. Fast reaction.
Hi there.. i seem to be experiencing the same issues mentioned above. could you please check mine?
thank you for the prompt response. been looking at this issue for the last 6 hours now. went down a few rabbit holes. glad its sorted nevertheless. thanks again!
Could it be that I’m using a Brave Browser? The remote access turns on when i fix it and then within 10 seconds it goes “no remote access”. I will turn it on again and the same thing happens over and over.
Hello, I believe I may be having the same issue. Could it be checked please?
Many thanks
