Plex shared folder movies not showing on different Volume
Server Version#:1.40.2.8395.7000
I have an DS923+ 2 disk on RAID1 (Volume1) 1disk RAID0 (Volulme2) 1 SataSSD cache for Volume2, 2 m.2 ssd cache for Volume1.
I have an old plex share on Volume2(raid1). I have a new Plex share on Volume 2 (Raid0)
If I download files to the new share via Synology Download center, The LG TV not showing the new files.
I can see the files on the NAS. The automatic directory scan is enabled on both Shared folder. The folder access right are the same. If I download files to the old folder (Volume1 Raid1) the files shows on LG TV quickly. That is the solution, I need to remove the old share and use the new one. Thank you for any help you can provide.
Nandor
Did you forget this step?
(It’s the popup message when Plex finishes installing . :wink: )
No, I gave permission to PlexMediaServer.
Anyway it seems only a file name bug because of continuous filename for series.
I renamed the .mkv files and plex can see it, BUT the movie index picture and infor are wrong. (why?)
Thank you.
