Plex stopped matching Movies. TV shows have continued to work fine
Update: Found the problem. The VPNBypass ([How To] Bypass VPN for Plex - General / General Discussions - Plex Forum) was causing my issue. Stopped the service and seems to be fixed.
I recently moved, and kept all my routers and configuration the same. TV shows have continued to match fine and grab metadata as usual. Movies however have stopped matching automatically, and returning no results when I manually search for matches as well using Plex Movie agent. If I use TheMovieDB, I can manually match the movies, but metadata still fails to grab then also. I cannot access plex.tv from my server machine either I noticed.
Any ideas on how to fix? Are logs needed?
Server Version#: 1.21.3.4021
