Plex support articles do not help
Server Version#: 1.41.1.9057-72009057
Player Version#: idk what this means
This article
https://support.plex.tv/articles/204281528-why-am-i-locked-out-of-server-settings-and-how-do-i-get-in/
Tells me to open preferences, but … preferences.xml is empty with just what is below.
Plex was working for 2 years until i updated, I have learnt my lesson and will never update this again. How in the @&$^@&$^do I fix this?
<Preferences OldestPreviousVersion="1.41.1.9057-af5eaea7a" MachineIdentifier="064379ef-5d45-48fe-b066-9e257c891c01" ProcessedMachineIdentifier="60ccea76a6b4f58fcf40e0065ec5eaada8400626" AnonymousMachineIdentifier="d1d15f79-658d-40bb-bd04-f8015a6f9170" MetricsEpoch="1"/>
■■■■■■■ piece of ■■■■
Moderator edit to show hidden XML
No idea how it happened but what you show here can happen when PMS doesn’t shutdown cleanly. (DSM upgrade or otherwise)
Did you also update DSM to 7.2.2 ?
Fixing it is trivial.
  1. Uninstall the package with the “KEEP” option
  2. Reinstall the same SPK again
  3. HOWEVER – Use the Plex Claim Token option
  4. Click 'Get Plex Claim token"
  5. In the tab which opens , COPY the token
  6. Return to the installer page and PASTE the token into the box.
  7. Click NEXT - NEXT - DONE
PMS will reinstall AND reclaim it for you again.
@ChuckPa Thanks for the response.
I tried that yesterday, I get this message when I tried again.
@shapter
That error will occur when the installation scripts can’t talk to Plex.tv
The most common errors come from configuration / network errors.
Go to Control Panel → Network → Network Interface
Confirm the primary adapter you’re using has:
  1. DNS setting pointed to your modem/router -OR-
    – 8.8.8.8 -or- 8.8.4.4 -or- 1.1.1.1 -or- 9.9.9.9
  2. Make certain the interface is set as the Default Gateway
  1. After saving this, open Package Center and confirm the Syno can talk to Synology and get a list of installable packages. (just look at them)
  2. If you’ve had to make changes and it now works, repeat the uninstall - install process again using the Plex Claim Token.
  3. If not, come back and let me know your status.
