tsanga
1
Server Version#: 1.32.2.7100
Synology DS418Play on DSM 7
Hardware transcode used to be working, but now I keep seeing this error in the logs:
[FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Can someone point me in the right direction for fixing it?
mcury
2
Check this topic: 1.32.2.7002
There is a regression in the Server Version#: 1.32.2.7100 for J3xxx and J4xxx CPUs, so for now, you should downgrade to build 6999.
Thank you for the heads up.
Pili
4
Hello,
That’s strange, on my 920+ with J4125 cpu, the hardware transcoding still work even with the 1.32.2.7100 of pms (installed with docker)
(I can’t post a screenshot, don’t kown why…)
