Das habe ich leider alles schon durch, habe über mein Laptop (der ist nur für die Arbeit, dort war noch nie Plex installiert) mich an der Qnap angemeldet und Plex gestartet, er erschein nur die Client Version, ohne Möglichkeit den Server einzurichten.
Correct
What’s the IP of your QNAP?
159.197.4.10
Bad IP!
See Qnap faq.....read me first! Q22
And if so, use the Linux version of ClaimIt, copy to anywhere on your QAP, and run it via like Putty
Then use 127.0.0.1 as the IP Address when asked
Ok. Thanks, i change the IP Adress later and try it.
Now its Family Day…
Many Thanks.
It works, I’m going crazy.
Such a simple solution, if only the F.A.Q reads correctly.
Thank you for your efforts.
You’re welcome, and huge thanks for reporting back here
And FYI:
what???
I didn’t install Claimit for Linux on my Qnap. Should i do ?
It works without it.
No need, since all is great
