PMS isn't downloading metadata
Over the past week PMS has stopped downloading metadata (posters, actors, episode info, etc) for my tv shows and movies.
Any advice on fixing this without reinstalling?
I've put a lot of work into my library in terms of editing metadata, covers, Australian ratings, etc.
I have PMS Version 0.9.8.18.290-11b7fdd on Mac OS 10.9.1
I am in the same boat. No metadata is being scraped for new movies.
Mac OS X 10.9.2
PMS 0.9.9.5
I attached some screen shots to help illustrate what I am seeing. I had to manually go out and get The Hunger Games and Nebraska Posters.
Any ideas, anything I can provide to help troubleshoot?
After digging through the forums I finally found the solution to my problem. The funny thing is, this seems like a fairly well known fix to a well known problem, but is difficult to troubleshoot by searching the forums because of so many different types of metadata issues. Would have been nice if someone could have chimed in to help....Hope this helps DarkSteel
If you've been hit by this problem, you can resolve it by taking the following steps:
  • Quit the media server by selecting the Plex icon in your Mac's menu bar, and choosing "Quit" from the drop-down menu.
  • Open the folder "/Users/(username)/Library/Application Support/Plex Media Server/Plug-ins" in Finder.
  • Delete "Framework.bundle", and "System.bundle" or move them to the trash.
  • Restart Plex Media Server.
You're amazing! Thanks very much!
This worked! Thank you ;)
Within the last couple weeks, I'm also having the same problem. It seems to have started spontaneously. I tried your fix, but unfortunately I'm still not getting any metadata for recently added movies or shows. Any other suggestions?
EDIT: Never mind, I did it again and now stuff's getting picked up. Thanks!
Worked like a charm... thanks!
Holy crap...thought I was going crazy...THANKS FOR THE SOLUTION!!!!
This doesn't solve mine UNTIL I forced refresh. Thank you. Now I can sleep. :)
About 3 days ago my metadata stopped getting downloaded for new shows.  I tried the steps in Powertowerpro's post and did a force refresh but it didn't seem to work.  Anyone else running into this? Any suggestions for things to try?
[Update: Ok I did the force refresh again and I think it's working this time, sorry for the forum clutter.]
This seems to happen more often for me lately. I have had a couple movies do this last week and now 1 series of TV shows did the same.
Hi Guys
Just a quick question, after the latest updates my issue is as follows :
For some strange reason i had to delete my PMS and PHT in order to get the trailer feature working properly. i have a few folders Movies 1/2 Bluray etc. Now when PMS did the original scan no problems all cover art etc showing.
When it came to some of my folders ie Movies 1 is seems to have only got an image from the movie (random scene) for the life of me i do not know how this has happened.
The only fix i found for this was to go into each movie PMS and click "fix incorrect match" the all is ok cover art showing with extra's, to be honest do not really want to have to go through each movie and do this.
Would this be a fix and did you guy's have the same problem.
Thanks in advance
I am having the same problem. My scanning agents disappear from PMS settings, and custom search settings and even adding a new library. I stop Plex, delete the two .bundles and start again. Things work normally for a couple of minutes, then the agents go awol again.
Does this have to do with the fact that I'm on OSX 10.7.5?
I'm back to verify that upgrading my OS to Mavericks solved this problem permanently for me.
The only way I get metadata to work on my TV shows is to use iFlicks. See below. The first two processed with iFlicks - same files, same filenames, etc. - the last 8 haven't been. Ran them through iFlicks and now they have the correct metadata, too. If I just rely on Plex, it doesn't work. I tried the answer above, twice, once with deleting the entire show and re-adding it, and nothing works.
@PowerTowerPro_ said:
After digging through the forums I finally found the solution to my problem. The funny thing is, this seems like a fairly well known fix to a well known problem, but is difficult to troubleshoot by searching the forums because of so many different types of metadata issues. Would have been nice if someone could have chimed in to help…Hope this helps DarkSteel
If you’ve been hit by this problem, you can resolve it by taking the following steps:
  • Quit the media server by selecting the Plex icon in your Mac’s menu bar, and choosing “Quit” from the drop-down menu.
  • Open the folder “/Users/(username)/Library/Application Support/Plex Media Server/Plug-ins” in Finder.
  • Delete “Framework.bundle”, and “System.bundle” or move them to the trash.
When I access this folder the only other folder is Services.bundle - is something going wrong here? I’m having the exact issue described but can’t seem to find the fault.
I am having the same problem. When I access the older I only see Services.bundle. I do not see a Framework. bundle"
It seems like this is a fix for older version of Plex. I’m having the same problem and still digging through the forum for a solution :((
Same here, can anyone offer any help
Would love to get the plex pass, but if this is not working now I cannot see having the pass make it any different
