Yep, it has severly regressed since 5080 I believe
I compared it to a Jellyfin and Kodi instance just to check if it’s not my connexion and it’s a flawless experience on both.
On Plex (at least for newer versions)
Live TV constantly buffers.
Plex HTPC doesn’t want to tune in a channel
Plex Android will infinite buffer at some points
Plex Web will kill stream after 4 minutes
Rolling back works but since I’m on newer intel CPU I need the new transcoder.
I’ve encountered a similar issue with the playback stopping every 4 minutes or so with Plex 1.25.3.5409 virtualized on a proxmox server. My web client is being run in Firefox and the “alternate streaming protocol” is unchecked.
The TV tuner being used is an Xteve proxy.
I have rolled back to 1.24.3.5033 and the live TV playback has been running continuously for about 20 minutes without interruption. It appears a regression continues to exist in the latest build of Plex.
Rolling back did not fix it for me, using either XTeve or my HDHR tuner. Tried PMS’s on both OSX and my Syno, web client, native OSX Plex client, native Windows client, Android TV client on Sony Bravia and Shield.
I have the same playback error issue, so far only with browser playback. Roku and Android play back fine.
I’ve used Edge (Chromium) and Firefox and within four or so minutes of playback the stream will quit and give the playback error.
I find it weird that there is no session under “Now Playing” in the dashboard using the Web player. Roku and Android playback sessions show immediately.
PMS: 1.25.4.5468
Tuners: HDHomeRun DUAL and HDHomeRun EXTEND
For reference, I believe about here (Jan 30, 2022 18:04:59.741 [6528] INFO - [I] ) in the Plex Tuner Service.log is where I started a session and about four minutes later the playback gives an error.
[Plex Media Server Logs_2022-01-30_18-08-49.zip|attachment]
The version of the webapp that is working is only available from https://app.plex.tv/web , the one that is bundle with the server won’t get the update for some time.
I have the same, but unfortunately with movies. The videos run 4-10 min on average and unfortunately it is stop and nothing goes further. Are the movies not working for you too?
I also have a few OTA channels that refuse to play on Plex Web but play just fine on Roku. It’s not every single channel though. Is it every single channel for you?
Ahh. I didn’t think about trying that, I always forget about https://app.plex.tv/web as I don’t use the web interface to playback content very much.
So far the minimal testing that I’ve done, app.plex.tv works fine.
It seems like most of the 1080 and 720 channels flake with the local PMS web interface but the suggestion from Tiebierius, the https://app.plex.tv/web works fine for me. I guess we will have to wait for the PMS server web interface to be updated for a fix.
