Poor picture quality when watching remotely using smart tv or ipad
Server Version#: 1.25.5.5492
Player Version#: 4.74.2
I have Plex running on my Synology NAS. When trying to watch content remotely, the sound is fine but the picture quality is very bad (blocky/pixelated). I believe it started happening after I upgraded the server version. It worked before so I tried resetting the settings to default in case I changed something that cause the issue. I tried setting the limits to be below the max upload speed. I also set automatic on so that it will adjust based on what Plex thinks. I know that feature is beta.
Not sure if anyone else experienced the same issue. Any suggestion will be gratefully received.
What are you seeing on the server dashboard while streaming a video remotely?
Does it show as remote or indirect?
Exemplary screenshot from the "now playing" section
https://support.plex.tv/articles/200871837-status-and-dashboard/
If you’re only getting an indirect connection, you might need to troubleshoot your remote access configuration.
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
If that’s not it… try disabling automatic quality.
Is your server powerful enough to transcode those files (if needed)?
There is an interesting development after some trail and error. If I use the app on my phone, the quality is still terrible. From the dashboard, it is showing as indirect. However, if I open plex in a browser, the quality is perfect. It is showing as remote. I assume now is to work out how I can config the app to be the same as the browser. Any suggestions or is this not really the fix.
Did you configure the Plex app on iOS to use a manual connection that might be pointing to an old/bad/broken URL/IP?
Edit: on a similar note… are you using some VPN or other network restrictions on your device (maybe w/ exceptions applied in mobile Safari)?
