Problem Emptying Trash
Server Version#: 1.18.4.2171
Player Version#: 4.20.1
Installed on MacOS 10.13.06
My Plex Server is not automatically deleting old, missing or deleted files.
I have tried to delete them manually, but get an error as below saying “There was a problem emptying the trash”.
I’ve downloaded the log files, but cannot seem to find what the problem is. Anyone able to help?
Plex Media Server Logs_2020-01-16_11-04-00.zip (7.0 MB)
Will it delete via info, bottom right Vertical ellipsis of file poster?
I don’t have an option to delete there??
The file that not available is on a different drive Plex 4TB 1, can you find it directly on that drive as a empty folder?
Plex dance the existing files will probably solve your issue
The Plex 4TB 1 was a different external HDD which is not longer connected to the Mac.
What do you mean by ‘Plex dance’ ?
You will need to remove the folder link in that Library, ok
Example:
That folder link has already been removed! Hence why I guess it wants to delete it. I saw another thread that talked about permissions, but I run it as the Admin and all permissions look OK.
Perform the Plex Dance as instructed in this article:
