Not sure where to even begin on diagnosing this issue. Most (99%) of my shows load meta data just fine, however, a couple shows aren’t seaming to want to load metadata! I can’t even go in an correct it manually, it just won’t match correctly even when I manually select the “correct match”…
Shows like, The OA, Anthony Bourdain: Parts Unknown, not working, loading anything, files play fine.
Now since my other shows load metadata just fine, i don’t think it’s a database issue or a grabbing/network issue… Leaving me with two possible situations, the files are not named correctly, (I have verified that they are named correctly) or something else is going on and I have not a clue where to look…
To test 1.15.3.876, I created a dummy series (shell script)
I get full results with names:
[chuck@lizum ~.369]$ ls /vie/tv*/The\ OA
Season 01/ Season 02/ Season 03/ Season 04/ Season 05/ Season 06/ Season 07/
[chuck@lizum ~.370]$ ls /vie/tv*/The\ OA/*
/vie/tv3/The OA/Season 01:
The OA - S01E01.mkv The OA - S01E06.mkv The OA - S01E11.mkv The OA - S01E16.mkv
The OA - S01E02.mkv The OA - S01E07.mkv The OA - S01E12.mkv The OA - S01E17.mkv
The OA - S01E03.mkv The OA - S01E08.mkv The OA - S01E13.mkv The OA - S01E18.mkv
The OA - S01E04.mkv The OA - S01E09.mkv The OA - S01E14.mkv The OA - S01E19.mkv
The OA - S01E05.mkv The OA - S01E10.mkv The OA - S01E15.mkv The OA - S01E20.mkv
/vie/tv3/The OA/Season 02:
The OA - S02E01.mkv The OA - S02E06.mkv The OA - S02E11.mkv The OA - S02E16.mkv
The OA - S02E02.mkv The OA - S02E07.mkv The OA - S02E12.mkv The OA - S02E17.mkv
The OA - S02E03.mkv The OA - S02E08.mkv The OA - S02E13.mkv The OA - S02E18.mkv
The OA - S02E04.mkv The OA - S02E09.mkv The OA - S02E14.mkv The OA - S02E19.mkv
The OA - S02E05.mkv The OA - S02E10.mkv The OA - S02E15.mkv The OA - S02E20.mkv
/vie/tv3/The OA/Season 03:
The OA - S03E01.mkv The OA - S03E06.mkv The OA - S03E11.mkv The OA - S03E16.mkv
The OA - S03E02.mkv The OA - S03E07.mkv The OA - S03E12.mkv The OA - S03E17.mkv
The OA - S03E03.mkv The OA - S03E08.mkv The OA - S03E13.mkv The OA - S03E18.mkv
The OA - S03E04.mkv The OA - S03E09.mkv The OA - S03E14.mkv The OA - S03E19.mkv
The OA - S03E05.mkv The OA - S03E10.mkv The OA - S03E15.mkv The OA - S03E20.mkv
/vie/tv3/The OA/Season 04:
The OA - S04E01.mkv The OA - S04E06.mkv The OA - S04E11.mkv The OA - S04E16.mkv
The OA - S04E02.mkv The OA - S04E07.mkv The OA - S04E12.mkv The OA - S04E17.mkv
The OA - S04E03.mkv The OA - S04E08.mkv The OA - S04E13.mkv The OA - S04E18.mkv
The OA - S04E04.mkv The OA - S04E09.mkv The OA - S04E14.mkv The OA - S04E19.mkv
The OA - S04E05.mkv The OA - S04E10.mkv The OA - S04E15.mkv The OA - S04E20.mkv
/vie/tv3/The OA/Season 05:
The OA - S05E01.mkv The OA - S05E06.mkv The OA - S05E11.mkv The OA - S05E16.mkv
The OA - S05E02.mkv The OA - S05E07.mkv The OA - S05E12.mkv The OA - S05E17.mkv
The OA - S05E03.mkv The OA - S05E08.mkv The OA - S05E13.mkv The OA - S05E18.mkv
The OA - S05E04.mkv The OA - S05E09.mkv The OA - S05E14.mkv The OA - S05E19.mkv
The OA - S05E05.mkv The OA - S05E10.mkv The OA - S05E15.mkv The OA - S05E20.mkv
/vie/tv3/The OA/Season 06:
The OA - S06E01.mkv The OA - S06E06.mkv The OA - S06E11.mkv The OA - S06E16.mkv
The OA - S06E02.mkv The OA - S06E07.mkv The OA - S06E12.mkv The OA - S06E17.mkv
The OA - S06E03.mkv The OA - S06E08.mkv The OA - S06E13.mkv The OA - S06E18.mkv
The OA - S06E04.mkv The OA - S06E09.mkv The OA - S06E14.mkv The OA - S06E19.mkv
The OA - S06E05.mkv The OA - S06E10.mkv The OA - S06E15.mkv The OA - S06E20.mkv
/vie/tv3/The OA/Season 07:
The OA - S07E01.mkv The OA - S07E06.mkv The OA - S07E11.mkv The OA - S07E16.mkv
The OA - S07E02.mkv The OA - S07E07.mkv The OA - S07E12.mkv The OA - S07E17.mkv
The OA - S07E03.mkv The OA - S07E08.mkv The OA - S07E13.mkv The OA - S07E18.mkv
The OA - S07E04.mkv The OA - S07E09.mkv The OA - S07E14.mkv The OA - S07E19.mkv
The OA - S07E05.mkv The OA - S07E10.mkv The OA - S07E15.mkv The OA - S07E20.mkv
[chuck@lizum ~.371]$
