Server not fetching TVDB metadata for specific shows
Hi! I’m using the latest version of PMS ( 1.18.8.2527) on my PC and for the past ten or so days I’ve had this new interesting problem that has been bugging me.
Some TV shows that I add to my media server are finding their metadata quickly as normal. However, a few specific shows have been “not found” through search/match/fix match function. I scoured through their files (as I normally use Filebot religiously) to see if this was the issue, but its the same naming scheme that the other working shows are using exactly. In addition to this, a few shows that I have been back-filling with missing seasons will not load their metadata either.
Ive tried:
  • The Plex Dance
  • Reinstalling PMS
  • Rebooting
  • Removing/re-adding content
This is from my server log when I try to manually find the content:
2020-03-20 19:13:58,015 (1fa0) : DEBUG (networking:138) - Fetching ‘https://tvdb2.plex.tv/series/153021?lang=en’ from the HTTP cache
2020-03-20 19:13:58,039 (1fa0) : WARNING (data:179) - Error decoding with simplejson, using demjson instead (this will cause a performance hit) - Expecting value: line 1 column 1 (char 0)
2020-03-20 19:13:58,053 (1fa0) : DEBUG (networking:143) - Requesting ‘https://meta.plex.tv/tv/names/en/6a/6ac9bf43972dc838e52c86288c24c360bc3b7448.xml
2020-03-20 19:13:58,253 (1fa0) : DEBUG (networking:143) - Requesting ‘https://meta.plex.tv/tv/names/en/5e/5eb965dd8c804a3a2833ac61fe1d1f6b1960735a.xml
2020-03-20 19:13:58,407 (1fa0) : DEBUG (networking:138) - Fetching ‘https://tvdb2.plex.tv/series/153021?lang=en’ from the HTTP cache
2020-03-20 19:13:58,433 (1fa0) : WARNING (data:179) - Error decoding with simplejson, using demjson instead (this will cause a performance hit) - Expecting value: line 1 column 1 (char 0)
2020-03-20 19:13:58,434 (1fa0) : INFO (logkit:16) - Skipping match with id 153021: failed TVDB lookup.
2020-03-20 19:13:58,434 (1fa0) : INFO (logkit:16) - Searching for exact match with: The+Walking+Dead (lang: en)
2020-03-20 19:13:58,434 (1fa0) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.t/search/series?name=The+Walking+Dead
2020-03-20 19:14:05,086 (1fa0) : DEBUG (runtime:88) - Sending packed state data (607 bytes)
2020-03-20 19:14:05,086 (1fa0) : DEBUG (runtime:924) - Response: [200] str, 320 bytes
I hope these two problems are related and can be fixed…
Any help is appreciated, thank you!
  1. how are your files named and structured - show us from the root out to the episode.
  2. are your files MKV / MP4 / M4V?
snippets of logs are less than useless. They never show what you think they show.
Prepare to gather some ‘DEBUG’ logs - NOT VERBOSE if asked, but we’re not there yet.
  1. My file structure goes as follows: Survivor → Season 01 → Survivor - S07E01 - Beg, Barter, Steal.mp4
I’ve followed this structure since I started my server about a year ago and haven’t had an issue like this one so far. I scrubbed all my files in the very beginning and renamed them all with filebot too.
  1. Its a mix of .mp4s and .mkvs. Shows will either be all one or the other.
Thank you :slight_smile:
Try this:
Refresh metadata, or:
Your file names look fine - if internal metadata in an MP4 file is the issue - the LMA Hack will fix that.
