Random Shows Refuse to play - Causes Player restart
Any Updates?
Any updates?
Any updates?
Any updates?
Any updates?
Any updates?
Any updates?
Any updates? It’s absolutely ridiculous that this very simple bug can’t be fixed.
Hi, I have this same issue using the Fire TV Stick 4K Max. Did you manage to reproduce the issue? I can send you the link of the file that cause my player to crash
I confirm the problem is the attached cover.png (7.4 MB) in the mkv file, after removing it the issue is gone.
I can send you a small sample file to reproduce the issue
Any updates?
if I have an update I will post it here or there will be a note about the fix in the release notes. I’m sorry i don’t have any new info to share.
Any updates?
Any updates?
Any Updates?
Any updates?
