RasPlex Support
I have another resolution question: I'm currently stuck in some weird "windowed" mode. I attached the RPi (RasPlex 0.2.2) via composite to an old TV and went thru ->preferences->System->Video to refresh rate and accidentially changed it from 60 to "windowed".
Now my screen is totally messed up (missing about 50% of the right side) and whatever I do, I seem not able to change it back... Anybody any idea how to fix this?
The same happens when I try to change the resolution... it just gets stuck in some windowed mode...
Any help would be highly appreciated!!
I've had a similar problem, I did it by hitting the wrong key on my keyboard. Try hitting \ (backslash) its the toggle windowed mode shortcut. This list may help too.
Thanks a lot for this. I played around and push buttons and whatever could be pushed and got out of the mode myself. Not sure how I did it in the end but your solution is much better and efficient! :) THANKS!
i have rasplex up and running just fine...
but i wonder if there is any info where i can find out witch key on the keyboard activate a specific command..
for example "space"=PAUSE "L"=subtitles
and so on...
is there any helpfile or pdf for that ??
i want to find how to delete movie from client and some other functions..
At first - Thanks a lot Dale!
I installed Rasplex on my 512mb raspberry and connected it to my home network with gigabit-ethernet. The PMS is on my iMac, everything works fine.
Except i noticed that some of my high-bitrate MKVs don´t play well. They stop every 5seconds, the start playing again, stop again... and so on.
Every MKV with less than 15000kbit/s seems to play well, everything above not (i just did some test - so 15000kbit/s might not be the exact threshold).
So it seems my connection from the Raspi to my iMac seems to be max. 2Mbyte/s.
Is there any way to get this connection work on a faster speed?
Does anybody have similar problems?
I'm having some issues with RasPlex resuming paused movies. I don't have any issue resuming on Android, Windows or a Samsung TV client, but whenever I attempt to resume on Rasplex, I get the following in my Server log.
Sep 01, 2013 23:56:40 [0x7f0d25ffb700] WARN - Couldn't set play progress on item 13501
Sep 01, 2013 23:56:51 [0x7f0d25ffb700] WARN - SLOW QUERY: It took 270.000000 ms to retrieve 79 items.
Sep 01, 2013 23:56:51 [0x7f0d2e7fc700] WARN - SLOW QUERY: It took 320.000000 ms to retrieve 93 items.
Sep 01, 2013 23:56:53 [0x7f0cf7fff700] WARN - Couldn't set play progress on item 13203
Sep 01, 2013 23:56:59 [0x7f0d2e7fc700] WARN - Couldn't set play progress on item 13203
Sep 01, 2013 23:57:21 [0x7f0cf5ffb700] WARN - SLOW QUERY: It took 230.000000 ms to retrieve 79 items.
Sep 01, 2013 23:57:21 [0x7f0d277fe700] WARN - SLOW QUERY: It took 310.000000 ms to retrieve 93 items.
Also, I get a lot of those SLOW QUERY errors. Over and over every 30 seconds. Any thought about that? I have optimized the DB. Not sure what is happening there, but it doesn't see to affect the performance of the other clients.
Rasplex will also not FF.
Upgraded to 0.2.2 to see if that would resolve the problem, but is has not.
Thanks for any help.
Changed the logging to verbose and debug and now things look like this.....
Sep 02, 2013 01:03:59 [0x7f0d27fff700] VERBOSE - Comparing request from 192.168.0.21 against 192.168.0.0/255.255.255.0
Sep 02, 2013 01:03:59 [0x7f0d27fff700] DEBUG - Request range: 0 to 0
Sep 02, 2013 01:03:59 [0x7f0d27fff700] DEBUG - Play progress on 13203 'The Expendables 2' - got played 289307 ms by account 1!
Sep 02, 2013 01:03:59 [0x7f0d27fff700] VERBOSE - Completed request: GET /:/progress?key=13203&identifier=com.plexapp.plugins.library&time=289307&state=playing: 206
Sep 02, 2013 01:03:59 [0x7f0d6f7fe700] VERBOSE - Finished writing response for GET /:/progress?key=13203&identifier=com.plexapp.plugins.library&time=289307&state=playing, 0 bytes in 2033ms
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] DEBUG - Request: GET /:/progress?key=13203&identifier=com.plexapp.plugins.library&time=295020&state=playing [192.168.0.21:35331] (6 live)
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] DEBUG -  * key => 13203
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] DEBUG -  * identifier => com.plexapp.plugins.library
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] DEBUG -  * time => 295020
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] DEBUG -  * state => playing
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] VERBOSE - Comparing request from 192.168.0.21 against 192.168.0.0/255.255.255.0
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] DEBUG - Request range: 0 to 0
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] DEBUG - Play progress on 13203 'The Expendables 2' - got played 295020 ms by account 1!
Sep 02, 2013 01:04:05 [0x7f0d2e7fc700] VERBOSE - Completed request: GET /:/progress?key=13203&identifier=com.plexapp.plugins.library&time=295020&state=playing: 206
Sep 02, 2013 01:04:05 [0x7f0d6f7fe700] VERBOSE - Finished writing response for GET /:/progress?key=13203&identifier=com.plexapp.plugins.library&time=295020&state=playing, 0 bytes in 5889ms
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] DEBUG - Request: GET /:/progress?key=13203&identifier=com.plexapp.plugins.library&time=300935&state=playing [192.168.0.21:35332] (5 live)
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] DEBUG -  * key => 13203
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] DEBUG -  * identifier => com.plexapp.plugins.library
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] DEBUG -  * time => 300935
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] DEBUG -  * state => playing
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] VERBOSE - Comparing request from 192.168.0.21 against 192.168.0.0/255.255.255.0
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] DEBUG - Request range: 0 to 0
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] DEBUG - Play progress on 13203 'The Expendables 2' - got played 300935 ms by account 1!
Sep 02, 2013 01:04:11 [0x7f0d2d7fa700] VERBOSE - Completed request: GET /:/progress?key=13203&identifier=com.plexapp.plugins.library&time=300935&state=playing: 206
Sep 02, 2013 01:04:11 [0x7f0d6f7fe700] VERBOSE - Finished writing response for GET /:/progress?key=13203&identifier=com.plexapp.plugins.library&time=300935&state=playing, 0 bytes in 5876ms
James
hi guys i am new to rasplex, i am trying to open raspi-config to overclock but i get this:
login as: root
# OpenELEC - The living room PC for everyone #
# ...... visit http://www.openelec.tv ...... #
rasplex Version: 0.2.2
root@192.168.1.136's password:
RasPlex:~ # raspi-config
-sh: raspi-config: not found
RasPlex:~ # sudo raspi-config
-sh: sudo: not found
RasPlex:~ #
i have tried every combination to no avail, always not found, any ideas?
thank you.
anybody here to help?
I'm pretty sure overclocking on rasplex is achieved through adjusting values in the config.txt file
thank you gb100, i saw rapi-config at the initial set up but now i cant get it back now, i even erase the SD card and installed again and still nothing.
besides, i dont just want to overclock.
Initial rasplex support post!
Can we get some link info in the first post please.  Or is the first test to use this product your knowlege of google?  :-)
Ignore me... I didn't see this had it's own forum.  Sigh...
Hi, I've just found PLEX (woop) and I have the server on my Win7 PC, and a client on Samsung TV working fine. I tried 0.2.2 (and 0.2.1) of rasplex and whilst the UI is there, and my library is there, it will not play any movies or audio. When I play a movie I started watching on my samsung, the rasplex correctly asks if I wish to continue from a time or at the start so it seems all communication is there but when I press play, it's as if I never pressed anything. When I try to play music a message briefly flashes up for a few times like it's re-trying.
I can post logs etc - just ask - but wondered if I'm just missing something.
This is probably related to limited codec support on the RPi. The RPi is only able to play h264 encoded video and AAC audio (AC-3 paththrough is possible as well). It's possible to add some more formats (MPEG2, VC-1) by purchasing a license (http://www.raspberrypi.com/license-keys/) and add the code to your RPi (search the forum/web on how to do this).
But your PMS should convert media on-the-fly for your RasPlex if it's capable enough. You may want to try to force transcoding too (go to settings -> network).
Interested in testing version 0.3.0 but can't get the newest 0.3.0 release via the releases list of the installer (doesn't appear in the list).
Can't find the direct link to the download either http://sourceforge.net/projects/rasplex/files/release/
Found the .tar for it but unsure how to create and .img file for it, please help.
Sorry - it seems I've mixed some release files and accidentally deleted the image file…
It should be available again now. (http://sourceforge.net/projects/rasplex/files/release/rasplex-0.3.0.img.gz)
Just a quick info for all waiting for 0.3.1: The release will be delayed until Friday. Sorry...
The aim is to get an updated version of the rasplex-updater into 0.3.1 too (this will allow to update to future bleeding releases again).
Thanks for this - I get further now - when I select a film it says "please wait" (the option was force transcoding on local network). Still nothing after that. Plus the music channels shows my iTunes library but just keeps popping up "please wait" until it reboots so I guess that's no codec issue - no point in buying codecs if this doesn't work. I have the plex log for trying to play a track from my iTunes library but the log is pretty big - seems to try & play/get info for the whole directory - a snippet is:
Oct 03, 2013 18:44:01:895 [5916] DEBUG - Request: HEAD /music/iTunes/Albums/1932/1910.mp3 [192.168.0.2:60998] (3 live)
Oct 03, 2013 18:44:01:896 [5916] DEBUG - Plug-in com.plexapp.plugins.itunes has been used 111 times.
Oct 03, 2013 18:44:01:923 [5916] DEBUG - Found an ID3v2 tag at start of MP3 file with size 1327, skipping.
Oct 03, 2013 18:44:01:923 [5916] DEBUG - Content-Length of C:/itunes/Music/Adele Discography/Adele - 19 [Expanded Edition] (2008)/CD 1/01-Daydreamer.mp3 is 4049356.
Oct 03, 2013 18:44:03:020 [6388] DEBUG - Request: GET /music/iTunes/Albums/1932/1910.mp3 [192.168.0.2:60999] (3 live)
Oct 03, 2013 18:44:03:021 [6388] DEBUG - Request range: 0 to 0
Oct 03, 2013 18:44:03:021 [6388] DEBUG - Plug-in com.plexapp.plugins.itunes has been used 112 times.
Oct 03, 2013 18:44:03:023 [6388] DEBUG - Found an ID3v2 tag at start of MP3 file with size 1327, skipping.
Oct 03, 2013 18:44:03:023 [6388] DEBUG - Content-Length of C:/itunes/Music/Adele Discography/Adele - 19 [Expanded Edition] (2008)/CD 1/01-Daydreamer.mp3 is 4049356.
Oct 03, 2013 18:44:04:133 [5916] DEBUG - Request: HEAD /music/iTunes/Albums/1932/1912.mp3 [192.168.0.2:61000] (3 live)
Oct 03, 2013 18:44:04:134 [5916] DEBUG - Plug-in com.plexapp.plugins.itunes has been used 113 times.
Oct 03, 2013 18:44:04:136 [5916] DEBUG - Found an ID3v2 tag at start of MP3 file with size 1333, skipping.
Oct 03, 2013 18:44:04:136 [5916] DEBUG - Content-Length of C:/itunes/Music/Adele Discography/Adele - 19 [Expanded Edition] (2008)/CD 1/02-Best For Last.mp3 is 4911920.
etc
Cheers for uploading it!
Can't upgrade from 0.2.2 to 0.3.1 because the upgrade.py says there was no space left. That's a bummer. Can somebody help me out here? Turning it off and on again didn't help ;) Thanks a lot!
Disk usage:
RasPlex:~/.plexht/temp # df -h
Filesystem                Size      Used Available Use% Mounted on
devtmpfs                148.9M    124.0K    148.8M   0% /dev
/dev/mmcblk0p1          249.7M    121.6M    128.1M  49% /flash
/dev/mmcblk0p2            1.2G    292.8M    859.1M  25% /storage
/dev/loop0              111.6M    111.6M         0 100% /
tmpfs                    60.3M         0     60.3M   0% /dev/shm
tmpfs                    10.0M    524.0K      9.5M   5% /var
Error message of update.py:
21:40:45 T:2865898592   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type:
                                            Error Contents: [Errno 28] No space left on device
                                            Traceback (most recent call last):
                                              File "/usr/share/xbmc/addons/script.rasplex.update/resources/lib/update.py", line 172, in
                                                Updater.update(url)
                                              File "/usr/share/xbmc/addons/script.rasplex.update/resources/lib/update.py", line 138, in update
                                                archive = Updater._download(url)
                                              File "/usr/share/xbmc/addons/script.rasplex.update/resources/lib/update.py", line 108, in _download
                                                archive,m = urllib.urlretrieve(url, reporthook=__reportProgress)
                                              File "./Lib/urllib.py", line 93, in urlretrieve
                                              File "./Lib/urllib.py", line 271, in retrieve
                                            IOError: [Errno 28] No space left on device
                                            -->End of Python script error report<--
Sorry - it seems you have to upgrade manually: https://github.com/RasPlex/RasPlex/wiki/Update
Worked like a charm. Thanks!
