Installed the latest build (.24) and then manually set a static IP address and the address to the PMS, and it resolved the network flooding issue. Things are still pretty sluggish, and videos don't play, though.
I'll wait for the next build, and give you updates when I get that rolling!
I've been using Openlec on my daughters old crt tv in her room not the best picture but its ok for her. I put rasplex on the SD card but there is nothing on the screen, I can see rasplex has started because it shows on plex on iphone when I press the tv icon at the bottom (players) plexhometheater on raspberry is showing . Is Rasplex set up for hdmi output only and if so is there a way I can get it to composit.
No videos play? Are you trying to play through the fanouts, or did you navigate to through the TV shows /movies area?
The UI is known to be a bit sluggish, but all of my playback tests have worked.
Did you try forcing local transcode?
No videos play. I tried playing from the fanouts, by navigating direct to the movies area, and by initiating the play function from the iOS app. None of them worked.
I have tried rebooting, but have not tried forcing local transcode. Is there a setting for this somewhere?
Plex IOS app should see the PI. did you login with myplex ?
There are some remoting issues still with IOS app, but it should see the pi without any specific settings
FLAC music should play.
Video channels are not yet operationnal.
Video channels are known not to work. I need help from Plex Inc to get it working. Very few of them work (crackle works for some reason). Most don't.
Thanks LongChair and dale.
Not sure what the problem is then as I cannot for life of me get the iOS app to see RasPlex? I'm logged into myPlex and the XBMC iOS App works? Also on the PLEX iOS App I can see the Pi as a AirPlay server?
I've seen this before, it might be related to overclocking... not sure though.
Are your SD Cards SDHC 10?
Yes. The two cards I have tried with 1.25 is both 16 GB class 10. One of them is a fast card (45 MB/s); Win32 Disk Imager writes the image 3 times faster on this one.
What is the correct settings in config.txt for no overclocking?
Found the no overclocking settings in config.txt. Edited config.txt, and it looks promising. will let it stay on overnight.
Hey I just installed the new Bleeding Edge 1.25 and wanted to let you know that when you choose shutdown, that it doesn't in fact shutdown but go back to the loading screen. Seems the only way to power down is to pull the plug, and I really don't want to corrupt the SD card. Anyone else get this problem too?
