I am looking for a solution to my media streaming across my house.
I have 2 roku players, one in the Living Room and one in the Bed room with Plex client. One of my PC is running the plex media server and it does the job right. I want to replace the Plex media server using Raspberry pi, use a bittorrent client, attach a terabyte HDD, access it using a VNC or similar client and connect directly to the router so that internet is uninterrupted.
Will the RASPLEX work in such an arrangement ?
The raspberry PI in this case would replace one of your roku clients, not the PC server.
I just ran the installer, and all that's loaded is XBMC which was on it before.
Will install rasplex-0.1.30.img.gz
Please ensure you've inserted your SD card, and press Enter to continue.
Enter the 'IDENTIFIER' of the device you would like imaged:
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *256.1 GB disk0
0: *3.0 TB disk1
0: *3.0 TB disk2
0: *1.5 TB disk3
0: GUID_partition_scheme *160.8 GB disk4
0: zfs_pool_proxy daniel *160.0 GB disk5
0: GUID_partition_scheme *3.0 TB disk6
0: zfs_pool_proxy titan *3.0 TB disk7
0: *1.5 TB disk8
0: GUID_partition_scheme *3.0 TB disk9
0: FDisk_partition_scheme *1.0 GB disk10
Enter your choice here (e.g. 'disk1', 'disk2'): disk10
It is your own responsibility to ensure there is no data loss! Please backup your system before imaging
Are you sure you want to install rasplex to '/dev/disk10' [y/N]
y
It appears that the rasplex installation image has already been downloaded. Would you like to re-download it? [Y/n]
n
Unmounting all partitions...
Unmount of all volumes on disk1 was successful
Please wait while rasplex is installed to your SD card...
This may take some time and no progress will be reported until it has finished.
0+26458 records in
0+26458 records out
1572864000 bytes transferred in 12.179430 secs (129141019 bytes/sec)
Installation complete.
rasplex is now ready to finish setup on your Pi, please insert the SD card with an active internet connection
Rasplex hackers:
Dale Hamel - Lead developer, builder, hoster, creator of rasplex (stubborn Canadian)
Robert Buhren - weelkin (lead of OpenELEC port)
Anil Daoud - Anil (Lead of Raspbian port)
Lionel CHAZALLON - LongChair (Lead tester, first user to join the channel)
Marc Massey - ElMassman (god of the GUI)
Andreas Weinlein - a_wein (autoupdate master)
Jay Smith - jsmith79 (stellar tester, helpful hacker, front line soldier)
Special thanks to:
Sam Nazarko (as well as the whole raspbmc team) - creator of Raspbmc, on which much of this work was based
Elan Feingold - creator of Plex - the best media center ever created
Tobias Hieta - maintainer of PlexHT, which made this port possible
GEWalker - creator of plex-linux, which got the ball rolling on this
Please donate at
http://srvthe.net
no word about it failing. i was expected to see somehting looking lke plex when booting. What am I missing?
I'm finding that the latest version (30) will have a black screen at some point after it has been idle for many hours (e.g. overnight) and a reboot fixes the problem. Earlier versions (including 29) never did this.
So, I bought a new SD card class 10 of course installed 1.27 and on first boot it went further than before. I was able to go into a section and bring up all movies before it froze. On subsequent boots it basically did what it did before, come up with sections after a minute or two the sections disappear and it freezes. Never git as far as the very first boot with a new card. Do I have a dud Pi or are we looking at the need for more maturation on the part of the software?
Turns out I replaced the power supply and now both my wireless keyboard and the Flirc works. I can play 1080P just fine. Two observations so far: The UI is real pokey and MPGE2 an I'd still like to know if it's d WMV don't play. Audio only. I'd still like to know if Retroplex can be used and what the steps are to get this skin installed.
Oh? 256 MB pi or 512?
I leave mine running all the time and i've never seen this.
0: *3.0 TB disk1
0: *3.0 TB disk2
0: *1.5 TB disk3
0: *1.5 TB disk8
y
n
0+26458 records in
0+26458 records out
Rasplex hackers:
Special thanks to:
Please donate at
http://srvthe.net
Im still having the problem watching 1080p movies only get sound no video.. I force transcode and then 1080p plays fine but i lose my surround sound dts only plays in stereo Im on the latest build
I had the same problem. But everything plays fine now on .30
The 512mb pi (the latest one), I've left version 31 on all day and it is still alive so perhaps it was just that version. Also switching between fanouts is almost instant, nice work!
Well, I've updated my RasPlex SD with 1.30 yesterday and I've noticed the Pi is no more rebooting when trying to view the videos of my queues (it used to reboot after like 10 seconds of trying).
Now, that's as if it was stuck trying to read the video but nothing happens... I can press "Return" and it will stop trying, but can't watch the videos...
I can read videos from a plugged USB hard drive though (I only could find my hdd files using the classic confluence skin, duno why)... but I wish I could use the queue feature (using the "Plex It" shortcut from my desktop computer to watch youtube videos and others).
I also noticed I could be stuck in the "search" screen with the "Return" of my TV remote (using CEC) that wouldn't work anymore... I had to reboot.
Since I've updated rasplex from .28 to .30/31 the CEC-functionality stops working when I turn my LG-TV off and back on. Now I either have to restart the raspberry pi, use the iOS remote. When I trigger a restart of the CEC-plugin (change a setting in the plugin-dialog using the iOS-App) the CEC-functionality comes back to life.
Well done to the guys working on this. Its coming along really well.
The two issues that I have come across so far:
I get stuck when trying to return from the search facility. The remote still works as I can delete and type letters but cannot return to home screen.
Since upgrading to .30 when I load all movies it takes roughly 20 seconds which seems longer than before. I have gone through and cached each movie poster with no effect.
