I’m not seeing where there was any new recording scheduled.
I am seeing database issues with long query times:
Mar 14, 2018 19:45:38.523 [0x700000bd6000] WARN - SLOW QUERY: It took 240.000000 ms to retrieve 23 items.
Mar 14, 2018 19:45:38.714 [0x700000ee8000] WARN - SLOW QUERY: It took 240.000000 ms to retrieve 5 items.
Mar 14, 2018 19:45:38.875 [0x700000f6b000] WARN - SLOW QUERY: It took 240.000000 ms to retrieve 40 items.
Mar 14, 2018 19:45:38.881 [0x70000020a000] WARN - SLOW QUERY: It took 220.000000 ms to retrieve 40 items.
Mar 14, 2018 19:45:38.893 [0x7000003a6000] WARN - SLOW QUERY: It took 450.000000 ms to retrieve 50 items.
Transcoder errors:
7958 Mar 14, 2018 18:06:57.483 [0x700002154000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 7 11
7959 Mar 14, 2018 18:06:57.486 [0x7000026f5000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] Warning MVs not available
7960 Mar 14, 2018 18:06:57.503 [0x700000ee8000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] Missing picture start code, guessing missing values
7961 Mar 14, 2018 18:06:57.516 [0x7000024e9000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] Missing picture start code, guessing missing values
7962 Mar 14, 2018 18:06:57.532 [0x700002360000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 5 1
7963 Mar 14, 2018 18:06:57.534 [0x700002778000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 43 8
7964 Mar 14, 2018 18:06:57.536 [0x700000b53000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] Invalid mb type in P-frame at 57 56
7965 Mar 14, 2018 18:06:57.536 [0x70000287e000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 68 28
7966 Mar 14, 2018 18:06:57.537 [0x70000256c000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 82 47
7967 Mar 14, 2018 18:06:57.538 [0x70000020a000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 91 65
7968 Mar 14, 2018 18:06:57.541 [0x700001406000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 84 19
7969 Mar 14, 2018 18:06:57.544 [0x700002672000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 4 1
7970 Mar 14, 2018 18:06:57.546 [0x7000025ef000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 34 13
7971 Mar 14, 2018 18:06:57.548 [0x7000009ca000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] 00 motion_type at 56 57
7972 Mar 14, 2018 18:06:57.551 [0x7000021d7000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 61 29
7973 Mar 14, 2018 18:06:57.552 [0x7000027fb000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 38 48
7974 Mar 14, 2018 18:06:57.553 [0x700000fee000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 119 66
7975 Mar 14, 2018 18:06:57.555 [0x700002466000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 67 20
7976 Mar 14, 2018 18:06:57.555 [0x7000026f5000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 31 7
7977 Mar 14, 2018 18:06:57.556 [0x700002154000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] 00 motion_type at 22 67
7978 Mar 14, 2018 18:06:57.558 [0x700000ee8000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] Warning MVs not available
7979 Mar 14, 2018 18:06:57.582 [0x7000024e9000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] Invalid mb type in B-frame at 39 30
7980 Mar 14, 2018 18:06:57.584 [0x700000f6b000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] skip with previntra
7981 Mar 14, 2018 18:06:57.584 [0x700002778000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] 00 motion_type at 83 60
7982 Mar 14, 2018 18:06:57.588 [0x700002360000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] slice mismatch
7983 Mar 14, 2018 18:06:57.589 [0x700000b53000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 80 29
7984 Mar 14, 2018 18:06:57.591 [0x70000287e000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] ac-tex damaged at 3 61
7985 Mar 14, 2018 18:06:57.591 [0x70000256c000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] 00 motion_type at 42 32
7986 Mar 14, 2018 18:06:57.593 [0x70000020a000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] 00 motion_type at 74 62
7987 Mar 14, 2018 18:06:57.594 [0x700001406000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] 00 motion_type at 111 33
7988 Mar 14, 2018 18:06:57.596 [0x700002672000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] 00 motion_type at 21 64
7989 Mar 14, 2018 18:06:57.598 [0x7000025ef000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] 00 motion_type at 28 67
7990 Mar 14, 2018 18:06:57.599 [0x7000021d7000] ERROR - [Transcoder] [mpeg2video @ 0x7fe693002a00] Warning MVs not available
7991 Mar 14, 2018 18:06:57.618 [0x7000009ca000] ERROR - [Transcoder] [ac3 @ 0x7fe693005c00] expacc 127 is out-of-range
7992 Mar 14, 2018 18:06:57.620 [0x7000027fb000] ERROR - [Transcoder] [ac3 @ 0x7fe693005c00] error decoding the audio block
7993 Mar 14, 2018 18:06:57.624 [0x700000fee000] ERROR - [Transcoder] [ac3 @ 0x7fe693005c00] frame sync error
7994 Mar 14, 2018 18:06:57.625 [0x700002466000] ERROR - [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
8223 Mar 14, 2018 19:17:53.934 [0x700000f6b000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8224 Mar 14, 2018 19:17:53.936 [0x700000b53000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8225 Mar 14, 2018 19:17:53.954 [0x7000003a6000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8226 Mar 14, 2018 19:17:53.996 [0x700001071000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8227 Mar 14, 2018 19:17:54.016 [0x700000f6b000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8228 Mar 14, 2018 19:17:54.034 [0x700000b53000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8229 Mar 14, 2018 19:17:54.095 [0x7000003a6000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8230 Mar 14, 2018 19:17:54.132 [0x700001071000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8231 Mar 14, 2018 19:17:54.154 [0x700000f6b000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8232 Mar 14, 2018 19:17:54.233 [0x700000b53000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
8233 Mar 14, 2018 19:17:54.253 [0x7000003a6000] ERROR - [Transcoder] [mpeg2video @ 0x7fe59b008200] Invalid frame dimensions 0x0.
