Remote access doesn't work
Server Version#:1.16.5.1554
Player Version#
I use my laptop as a plex server
laptop is connect to a router which is connect to a switch which is connect to modem
enble port forwarding doesn’t seem to work
enble UPnP doesn’t seem to work
what can I do?
usually the laptop would connect to a switch and after that a router.
can you disable upnp and post a shot of your port forwarding setup?
is there a firewall on the laptop you can disable for testing?
Ok. Thank you. I will try it
