Remote Access just stopped on my server..
Confirmed router port forwarding is correct…
restarted plex and router.. nothing.. Locally everything is fine.. remote, nothing.
I’ve DMZ my ip address. still not able to remote access
I’ve turned off firewall on the server, still not able to remote access
The remote access comes on for a few seconds then disables…
I have also used a different router, same settings… same issue..unable to remote access
I have contacted Spectrum.. they are not blocking
update:
turns out people can connect INDIRECT??
