Some Live TV dont playable via Vbox
Thanks for quick test
So any improvement from before ? Ones that failed before and now working?
examples?
I have referred it back to the development team - thanks for your help
What would be good to know is if more channels now tune than before
@NTLX could i have copy of the EPG database files
/Users/m1_home/Library/Application Support/Plex Media Server/Plug-in Support/Databases/tv.plex.providers.epg.xmltv-936ea3b8-bcc2-43c3-9fb2-1d0228838d54.db
/Users/m1_home/Library/Application Support/Plex Media Server/Plug-in Support/Databases/tv.plex.providers.epg.xmltv-936ea3b8-bcc2-43c3-9fb2-1d0228838d54.db-wal
/Users/m1_home/Library/Application Support/Plex Media Server/Plug-in Support/Databases/tv.plex.providers.epg.xmltv-936ea3b8-bcc2-43c3-9fb2-1d0228838d54.db-shm
Please copy out and zip
Let me know which version of PMS is running at the time of copying out the db files
Archívum.zip (2.2 MB)
Hello I use right now the latest best PMS version which is good for every vbox channels! 1.32.2.7100
So are these db files from the time when you are running on the working version ? 1.32.2.7100
Please find here the EPG DB files taken using PMS version 1.32.4.7195-7c8f9d3b6
Databases.zip (1.1 MB)
Plex Media Server Logs_2023-06-16_08-01-12.zip (1002.7 KB)
Also, a copy of my xml file:
vboxXmltv.zip (104.8 KB)
Do you have by any chance the PMS 64 bit version of this PMS server revision : 1.32.2.7100-248a2daf0 ? I found in my Updates folder from AppData only the x86 version.
Thanks,
Mihail
Many Thanks for the logs, EPG db and xmltv file - I have passed these on to the development team
Would you be able to repeat this test with debug logging enabled using the development build I sent you yesterday 1.32.4.7225 - refreshing the guide and then repeating the tests and capture the logs, EPG db files and xmltv file ?
Hi ,
I tested the version 1.32.4.7225, and for me the live tv is working correctly. One thing I needed to do though was to manually uninstall the old version before installing the test version.
EPG:
Databases.zip (1.3 MB)
PMS logs:
Plex Media Server Logs_2023-06-16_11-59-50.zip (1.3 MB)
I will remain for now with this test version, and report if I observe anything wrong.
The xml tv file is the same one as I attached in the previous post. It is extracted from the vbox device.
BR,
Mihail
So far so good, no problems observed. On the contrary, maybe it is only a feeling, but the response time seems to be better, and the overall channel to channel switching seems faster.
This is interesting - because it was not working for @NTLX
Wondering if the difference was a Guide Refresh with the development build version that fixed it for you
Do any of these work for you now - they did not for @NTLX
www.M1%20HD.co.un
www.DUNA%20HD.co.un
www.M5%20HD.co.un
www.TV2%20HD.co.un
www.RTL%20HD.co.un
www.ATV%20HD.co.un
www.RTL%20Gold.co.un
www.Jocky%20TV.co.un
www.TV2%20Kids.co.un
www.Da%20Vinci.co.un
www.MTV%2000s.co.un
www.ID%20HD.co.un
www.The%20Fishing%20%26%20Hunting%20HD.co.un
www.Sky%20News.co.un
@Mihail_RO @NTLX
The difference in your tests of the 1.32.4.7225 development build with the changes to fix the problem, is that a Guide Refresh was run before the test in one case and no Guide Refresh was done in the other
@NTLX please try again 1.32.4.7225 but before doing any tests, please refresh the guide and i am hoping that you will then have the same outcome as @Mihail_RO
The channels mentioned here are not from my xmltv.
I have TVR1%20HD , TVR2%20HD, almost all of my channles contain this %20, and I can confirm they all work.
I also have found the channel Fishing & Hunting in my channel list, which has this %26 ( & ) besides the space ( %20 ), and it is working for me.
BR,
Mihail
Yes, I have the problem again as well. Here are some logs.
Plex Media Server Logs_2023-07-17_16-19-32.zip (3.5 MB)
A fix will go into the next beta release after 1.32.5
I expect it to be in 1.32.6
The problem was with encoded channel identifiers on the vbox iptv setup
Plex Media Server 1.32.6.7371 has just been released as beta
  • (DVR) Tuning in channels could fail for channel names containing special characters (#14391)
I have just installed this version, and I cofirm the channels work correctly.
Also, compared to the test version I have been using, the channel loading is much faster.
BR,
Mihail
Hello,
The PMS has not been updated, I am still at the version 1.32.6.7371, but probably the Plex Player has, because again , the channels are not opening. On windows PC, the channels work only with HTPC and from the browser version, and not with the Plex for Windows App. Also on Google TV is not working, and neither on Android Phone app.
It’s really annoying…
I am really tired of this.
On August 4th you confirmed the fix in PMS did resolve the tuning issues with channels that had extended characters - was that test limited to some Plex clients?
If there are still issues - they need to be investigated in the same way as we investigated the original problem with diagnostics from the server and the client apps
Are you saying that a plex client that tuned ok on the 4th August is no longer tuning?
We had the following releases for the Plex Desktop app
18th July - version 1.74.1
1st August - version 1.75.0
15th August - version 1.76.2
I can make the 1.75.0 and 1.74.1 releases available to you if you don’t have them to try out and see if the issue is to do with a client update
If it is, would be good to get Plex Desktop App logs and debug Server logs from the working one and the also the failing one
I tested then all available players. Android Phone, Google TV app, Samsung Tizen, LG webos, windows plex player ( I did not test Plex HTPC for windows , but this works now ).
They all worked then.
Now, since a few days Google TV app is not tuning anymore, Android Phone app is not tuning since a few weeks ago, but blamed it then on other factors. Now more and more apps are not wokring, and most important for me the Googgle TV app is not working. I do not really use the Windows Plex app, and have no idea how to downgrade the Google TV app.
I can make some tests and provide you the logs using the google tv.
I tested now also the Samsung Tizen, and it is working. Cannot test LG webos yet, it might be working too, The problem mainly seems to be around android/google apps.
Mihail
I tried many channels using Google TV in the beginning… Only one of them worked ( Diva )
Then Android Phone app, which was even worse. I clicked a channel, and nothing happened. Only one channel has shown me the tuning error. The rest of them just did not respond to the click.
At the end I used Samsung Tizen, which tuned in the first attempt.
Logs attached.
Mihail
Plex Media Server Logs_2023-08-25_13-03-46.zip (1.2 MB)
