Some remote access stopped working
@lgibson71
You do not have this situation due to certificate issues.
Oct 10, 2020 10:24:16.407 [0xb4ffe700] DEBUG - ChangestampAllocator: initialized to 5383820
Oct 10, 2020 10:24:16.407 [0xb4ffe700] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
Oct 10, 2020 10:24:16.411 [0xb4ffe700] DEBUG - Running migrations. (EPG 0)
Oct 10, 2020 10:24:16.430 [0xb4ffe700] DEBUG - [CERT] Installed certificate with fingerprint e5:ac:3d:a7:a2:00:c7:0b:17:3e:d0:9f:21:ae:36:7e:fa:f5:03:8f.
Oct 10, 2020 10:24:16.430 [0xb4ffe700] DEBUG - [CERT] Installed new private key.
Oct 10, 2020 10:24:16.430 [0xb4ffe700] DEBUG - [CERT] Subject name is /C=US/ST=California/L=Los Gatos/O=Plex, Inc./CN=*.f5e846a57d8c443e90d80450ce89f31c.plex.direct
Oct 10, 2020 10:24:16.430 [0xb4ffe700] DEBUG - [CERT/OCSP] Stapling requests will be made to 'http://ocspx.digicert.com/'.
Oct 10, 2020 10:24:16.430 [0xb4ffe700] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Oct 10, 2020 10:24:16.430 [0xb4ffe700] DEBUG - [CERT] Installed intermediate certificate.
Oct 10, 2020 10:24:16.430 [0xb4ffe700] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Oct 10, 2020 10:24:16.430 [0xb4ffe700] DEBUG - HttpServer: Listening on port 32400.
Oct 10, 2020 10:24:16.430 [0xb4ffe700] DEBUG - HttpServer: Listening on port 32401.
Oct 10, 2020 10:24:16.435 [0xb2041b40] DEBUG - Grabber: Cleaning up orphaned grabs.
I see what looks like firewall problem (Plex Relay is starting)
I performed a reset anyway.
Please restart the server
If you still do not have remote access inbound, then I urge you to look at your firewall and port forwarding configurations.
@ChuckPa
I hope these are the logs you need. I saved the changes. I did check the issue is still happening for me.
Plex Media Server Logs_2020-10-09_17-01-43.zip (503.5 KB)
@ChuckPa Remote Access on my PMS started showing issues a couple of days ago after years of no trouble at all. I tried what I could but nothing worked, so here’s my info and logs.
Synology DS916+
Server Version 1.20.2.3402
Like others in this thread have mentioned, there’s a green check mark next to Remote Access for a few seconds before it turns red. No clients outside my network can access the server. Port forwarding to 32400 is enabled on my router, and UPnP is also enabled.
I’m hoping it’s an easy fix, thank you for looking into it.
Logs:
Plex Media Server Logs_2020-10-09_18-16-27.zip (3.2 MB)
@o_nicholas_protonmail_com
Do you have double NAT? (router being another router/modem) ?
Oct 09, 2020 16:59:03.801 [0x7f919e88f700] DEBUG - NAT: UPnP, found device <http://192.168.1.1:34609/rootDesc.xml> with private address <192.168.1.100>
@sigmastorm7
Reset
You may restart
Working great now, thank you!
I think so? I have the Fiber modem which is a gateway set to bridge mode. Then an Asus router that I actually use for my networking.
If you’ve handled the translations (bridge mode / transparent passthrough) then ok.
I looked at it and when I see cases of no remote access and this, it’s usually because of double NAT. (e.g. Public -> 10.x.x.x -> 192.168.x.x type stuff)
I’m having the same problem. I’m running PLEX (latest version) on my QNAP and it was working fine then suddenly starting a few days I cannot log in remotely from my Windows 10 PC. The browser (Firefox) gets stuck in some kind of loop as if it is trying to do something but just hangs in that state. I had the same problem accessing from my Mac using Safari.
Something got broke in the latest release.
@toddphi
It’s not the release else the world would be screaming.
There are a lot of variables in play.
If you go to Control Panel - Shared Folders, do you have a PlexData share?
If so, does your QNAP username have access to it?
If not existing, create it
otherwise, give yourself access to the shared folder (default is to not freely grant access to anyone)
Once done,
  1. Open FileStation
  2. Open PlexData
    2a. If you don’t see ā€œPlex Media Serverā€ just stop & restart Plex then reopen File Station. Starting Plex creates the entry for you regardless what happens.
  3. Click ā€œPlex Media Serverā€ (it opens again)
  4. RIght-click ā€œLogsā€ -> Compress to Logs.zip
  5. Let them compress
  6. When done, download the ZIP
  7. Upload here.
  8. I’ll look at it.
It’s probably related to the outage at Plex.tv when certificates got messed up a bit
Chuck! having the same issue. So here’s part of my issue. I use cell service for my wifi. So it creates a double NAT so i can not enable remote access. However i’ve never had an issue with indirect ( or my kids) accessing from any phone or amazon App. Any help would be appreciated Plex Media Server Logs_2020-10-10_07-28-27.zip (2.9 MB)
Hi @ChuckPa I thought I’d circle back here with my experience. (Maybe you reset my cert too? idk) Anywho… here’s the kung-fu I did on my end.
  • Signed out and shut down my Plex Server
  • Deleted all aged or outdated Authorized Devices shown on https://app.plex.tv/desktop#!/settings/devices/all … old devices, dead accounts, old browser revs, etc. FWIW, there was only one instance of my server shown.
  • Waited a good while >4hr
  • Restarted Plex Server
  • Logged in, and reclaimed the server
  • Secure access now working again
Don’t know if you had a hand in this on your side, but things seem to be happy here and I’m getting a green lock.
Cheers!
Cleaning it out helped some
Shutting down and letting plex.tv cool down is the biggest part. It’s very (sometimes overly) sensitive to request rates. It gets so many normal requests that it has active DOS monitoring.
If you had asked me to look then, somewhere along the way, I probably reset it.
Otherwise, I’ve been so ā€œcat in a room full of rocking chairsā€ busy that I can’t remember if yours was done or not.
Watch your tail, man. Appreciate your help + have a great day.
@jimhorner67
Which server please? You have 10 listed.
If some of those are inactive / no longer in use, might you be able to assist me by removing them ? (Settings - Authorized Devices - Servers (dropdown)
i deleted everything from the authorized devices. my server name is PMS_A Plex Media Server Logs_2020-10-10_15-21-20.zip (3.2 MB)
@jimhorner67
I reset the certificate although you should have received a fresh one anyway.
This will guarantee it.
You may now restart the server
still cant see my server on the app.
Reset the app (customization ) and re pin it
@ChuckPa
Can I send you logs to see? I think I’m having the problem
