I’ve given it a bit drop out .
The certificate has been reset
Please verify your computer clock is in sync with the internet time
Restart the server
Restart the server
That looks like it worked. Thank you!
Dumb question, but will we all need our certs reset to fix this issue?
I am curious as to how this will be fixed as a whole - I am now experiencing this issue as well.
@ChuckPa Thank You, here are my logs: Plex Media Server Logs_2020-10-05_09-40-27.zip (4.6 MB)
@ChuckPa
I hope you are not already to stressed
Maybe if you find some time you might also take a look in my logs
Plex Media Server Logs_2020-10-05_10-12-40.zip (2.2 MB)
Thank you very much…
@ChuckPa
Hi ChuckPa ! News from my problem ?
I have been able to get everyone working by following this sequence.
Let’s give that a try
@ChuckPa Confirmed resetting the cert on your side appears to have fixed the issue. I didn’t even need to restart my server and it started routing properly again (I could start casting just fine from android). However, the local machine for app.plex.tv still can’t find the server on the same local machine, but that server is visible with localhost.
@ChuckPa Hi !
Whats NTP time server ?
@ChuckPa Ok I think I did it let’s retry and cross the finger
I’m ready.
If I well undesrtand, I have to relaunch the server as soon as you doing the manipulation, that’s it ?
Hi, I’m having a similar issue. Remote access has stopped. This is my log file (downloading it for the first time). I have followed the above steps. Kindly let me know if anything is wrong and if this is the certificate issue or something else. Please help me reset it. Thank you!
Plex Media Server Logs_2020-10-05_20-46-20.zip (2.3 MB)
@ChuckPa Could you please check my files too and let me know?
OK, stopped server and syncd with 0.uk.pool.ntp.org
Server reset. you may start it now.
@ChuckPa Server is stopped
Thank you! Working perfectly again.
Much appreciated
@ChuckPa… How can I do ? What’s the problem
That’s strange i’ve got the same problem as everyone, He arrived at the same time as everone, but for me, it’s not working
That’s strange but since three day you already tried to reset my certtificate, thoses times, you had find one don’t you ?
I don’t know what you did – or did not do.
