Some remote access stopped working
I have stopped the server
@ChuckPa
Certificate reset.
You may start the host
Could you reset mine again as well please? Seems like last time I did something wrong and it didn’t work.
@ChuckPa
Server has been stopped
@jmsarel
There is no certificate for me to reset.
I need your logs.
@captainsockpuppet
It never claimed the first time.
I need your logs
@captainsockpuppet @jmsarel
Did you restart the server after I reset it before or are you still running without restarting?
@ChuckPa Here are the latest logs from the server.
I had restarted the server after you reset the cert the last time, and it did work briefly, but seems to have stopped again. Not sure why.
Plex Media Server Logs_2020-10-06_21-18-20.zip (3.2 MB)
@captainsockpuppet
Check your PM
@ChuckPa please see my attached logs, can you assist me as well with this issue.Plex Media Server Logs_2020-10-06_20-30-51.zip (1.6 MB)
@LMF455r
Do you still have 1.20.1 handy? If so, Please install it and retest.
New logs
Plex Media Server Logs_2020-10-07_04-37-45.zip (1005.8 KB)
I restarted afterwards last time. I’m going to turn it off now and turn it on after reset.
@jmsarel
This isn’t the certificate issue.
Oct 07, 2020 04:36:21.152 [0x7ff262b2f780] DEBUG - ChangestampAllocator: initialized to 140155861028205
Oct 07, 2020 04:36:21.152 [0x7ff262b2f780] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
Oct 07, 2020 04:36:21.155 [0x7ff262b2f780] DEBUG - Running migrations. (EPG 0)
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] DEBUG - [CERT] Installed certificate with fingerprint d0:f6:b7:c5:b7:4e:05:64:40:24:a8:9f:69:24:ac:f1:ac:ef:78:9a.
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] DEBUG - [CERT] Installed new private key.
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] DEBUG - [CERT] Subject name is /C=US/ST=California/L=Los Gatos/O=Plex, Inc./CN=*.ad18c3d60e944b8baf32fec43edb6a1f.plex.direct
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] DEBUG - [CERT/OCSP] Stapling requests will be made to 'http://ocsp.digicert.com/'.
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] DEBUG - [CERT] Installed intermediate certificate.
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] DEBUG - HttpServer: Listening on port 32400.
Oct 07, 2020 04:36:21.165 [0x7ff262b2f780] DEBUG - HttpServer: Listening on port 32401.
Oct 07, 2020 04:36:21.167 [0x7ff250e9e700] DEBUG - Grabber: Cleaning up orphaned grabs.
Oct 07, 2020 04:36:21.168 [0x7ff262b2f780] DEBUG - Media Provider: Registering provider com.plexapp.plug
This is something new :roll_eyes: in PMS 1.20.2
auth_token=xxxxxxxxxxxxxxxxxxxx&itemsCompleteCount=1&itemsCount=1&itemsDownloadedCount=0&itemsReadyCount=1&itemsSuccessfulCount=1&state=complete&totalSize=4657960762
Oct 07, 2020 04:36:24.656 [0x7ff249ffb700] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 07, 2020 04:36:24.732 [0x7ff1fa7fc700] DEBUG - HTTP 422 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct 07, 2020 04:36:24.732 [0x7ff1fa7fc700] DEBUG - MyPlex: Published Mapping State response was 422
Oct 07, 2020 04:36:24.732 [0x7ff1fa7fc700] DEBUG - MyPlex: Got response for aec75e5e92406f4e0041eabfe073e74c8fc0a1a8 ~ registered :0
Oct 07, 2020 04:36:24.732 [0x7ff1fa7fc700] DEBUG - MyPlex: updating mapped state - current state: 'Unknown'
Oct 07, 2020 04:36:24.732 [0x7ff1fa7fc700] DEBUG - MyPlex: mapping state set to 'Mapped - Publishing'.
Oct 07, 2020 04:36:24.732 [0x7ff1fa7fc700] DEBUG - MyPlex: async reachability check - current mapped state: 'Mapped - Publishing'.
Oct 07, 2020 04:36:24.732 [0x7ff1fa7fc700] DEBUG - MyPlex: Requesting reachability check.
Oct 07, 2020 04:36:24.732 [0x7ff1fa7fc700] DEBUG - HTTP requesting PUT https://plex.tv/api/servers/aec75e5e92406f4e0041eabfe073e74c8fc0a1a8/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=6901e114-4590-4b44-a2c5-e842c302c6e9
Oct 07, 2020 04:36:24.936 [0x7ff1fa7fc700] DEBUG - HTTP 200 response from PUT https://plex.tv/api/servers/aec75e5e92406f4e0041eabfe073e74c8fc0a1a8/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=6901e114-4590-4b44-a2c5-e842c302c6e9
Can you reinstall PMS 1.20.1 and also retest ?
Sorry - I do not.
Damn. There is no 1.20.1 docker on our server for me to get for you either.
I can get everything else.
Found it!
so change plexinc/pms-docker:latest to plexinc/pms-docker:1.20.1.3252-a78fef9a9
ANY PMS version can be used in docker this way. (Version tags)
Ref: https://hub.docker.com/r/plexinc/pms-docker/tags
Sorry, I may be misunderstanding - im running it on a Windows 10 machine.
@LMF455r
Let me see if I can find it and upload for you
I found a version for you.
Uploading to Gdrive now
@LMF455r
This is 1.20.1
It’s always advisable to keep at least 1 known-working version around.
It will help when uncertainties creep in.
I’m having this issue. Had no problems for years and now all of a sudden can’t access remotely. Checked all setting and port forwards are good.
