Some TV Shows Episode not showing
Server Version#: 1.18.2.2029
Hi
I have a small but annoying issue.
I have the latest episodes of The Walking Dead - Season 10. Plex is showing me Episode 1 and 2 but not 3 and 4. Then its showing me episode 5 and 6. But the 3 and 4 is not there. File names are correct and have checked permissions on NAS where files are storage, also ok.
I have tried re-sync several times but the files are not showing. Just tried to move some files to other folders and that works. It seems like the error is on Season 10 folder. I have attached the log files for the Plex Scanner right after.Plex Media Server Logs_2019-11-18_13-30-15.zip (3.5 MB)
Hi @carlsen2dk
There is an issue with www.tvdb.com
See:
I have seen that, but the files was added the 31/10. And the error we are now have with TVDB is a bit newer,
Well i think at this point we are unable to check the reason of your error.
Please be patient while they are working to fix this mess.
Sure think :slight_smile:
Found the solution my self. For some reason the files thought they were in another series folder. I deleted that from Plex and then did a re-sync. Now the files are located correct.
