no response from the Devs… awesome!!
Same issue for me. None of the 1.32.x.xxxx works for me. This is on win10.
Sorry - without diagnostics / server debug logs of the problem arising still on the latest version, I have nothing to go on.
We do have evidence of issues with certain namings of episodes that arose after the change to accommodate sonos episode ranges but would need actual logs to see if it is that or some other issue
For the scanning issues please try with the current beta 1.32.1.6999-91e1e2e2c and run with both verbose and debug logging enabled and then capture the server logs when the scan fails to add / detect the media files. Please indicate what was being added when attaching the server logs
Please disable verbose logging and keep just debug logging enabled after capturing the logs
As this thread was marked to have a solution, i created 1.32.1.6999 not adding new episodes/shows for TV with server logs included.
Are they enough?
I can confirm I have the same issue.
If I cut and paste back in the media it strangely find it , likewise if I remove a d add the library back.
Same issue here with Windows 11 PMS and Syno network shares.
@t21drl_gmail.com, I tried cutting, scanning, empty trash, pasting back, and rescan - still not successful on my end ![]()
