Subtitle problems while playing movies on samsung tv
Server Version#:latest
Player Version#:latest
My plex server is on the pc. I start playing movies on my Samsung TV and while playing the movie there are holes in my subtitles while playing. Can anyone help. Sometimes the subs are back and then again gone. Then back
Are we talking about SRT subtitles?
If so, make sure that these subtitles don’t contain “overlapping” subtitles. Meaning the time stamps of two lines would require them to be shown at the same time. This doesn’t work in many devices due to limitations of their SRT renderer.
You can check for and correct issues like these with Subtitle Edit. See Introduction: convert image-based subtitles to SRT with Subtitle Edit
The file is in srt and utf-8.but still there are holes in the subtitles.
Please read the second part of the linked article, where I talk about “Fix common errors”
I have the same problem on my Samsug TV; hole in my subtitles.
Never had that before, always worked perfectly… what happend?
I read the article but i dont understand any of that… i’m not a computernerd
Please, can this be fixed?
Yes, i solved the issue!
Go to settings and choose subtitles
Switch off automatic and use ALWAYS
Works for me …no more holes in the subtitles
Do we need 2 do the change the settings each Time we watch a movie. I want it standard settings so each time we don’t have 2 change it. Solution?
Found it, thx for helping me​:wink::wink::wink:
No, once you 've changed the settings, it remains on ALWAYS
