I’m having trouble with sweet fades in plexamp. They work about 80% of the time. When they don’t, the previous track will abruptly end and the new track will start. Sometimes the fade will seem so start, but the outro of the previous track will cut in-and-out over the intro of the next track. I have an iPhone 12 and the latest update. This started happening after I migrated my server in January. I’m not sure if that is just a coincidence though. Could my sonic analysis data have been corrupted during the migration? Is there a way to delete that data and have the files re-analyzed? I also have logs from plexamp if that helps.
Sweet fades don’t use the Sonic Analysis data, they use the Loudness Analysis. If you see the seekprint on the player, the loudness analysis is just fine.
Do you have strict sample rate matching enabled by any chance?
Share your Plexamp logs after you experience the issue, and they’ll likely tell the tale.
