I will certainly give everything a try.
Thank you for your input!
Alright, so I cleared cookies and uninstalled and reinstalled with claim code. It doesnât say itâs unauthorized. It now say âadd your mediaâ and to click âget Plex media serverâ download page.
I believe I found the logs, but I didnât see anything.
Processing: com.plexapp.agents.fanarttv (1).logâŠ
And oddly enough the devices I have linked to the syno, the content works just fine. I can watch TV shows and movies.!
May I see the logs please?
Well Iâm drawing a blank on finding the logs. Could I get some help?
If PMS is running and you have access Settings - Server - Troubleshooting - Download Logs
If not,
- Stop Plex
- FileStation: Navigate to PlexMediaServer â AppData â Plex Media Server
- Right-Click
LogsâCompress to Logs.zip - When done, Download to your computer
- Upload here
Logs.zip (2.0 MB)
Okay, Thanks!
Hopefully this works!
So I noticed somethings strange when moving between the admin account (which is the one I use the most, has a pin set so family members dont delete movies on purpose or accident). and the other family accounts family accounts have restristions etc. well under the admin account it says to add your media. but under a different account, its like nothing has happened, all media is in place and acts normal.
Maybe this sheds some more light or it complicates things more.
Thanks.
I have one immediate recommendation for you.
Notice you have two network adapters active on the same network?
Sep 06, 2022 04:47:48.017 [0x7f12732761c0] DEBUG - Detected primary interface: 192.168.106.6
Sep 06, 2022 04:47:48.017 [0x7f12732761c0] DEBUG - Network interfaces:
Sep 06, 2022 04:47:48.017 [0x7f12732761c0] DEBUG - * 1 lo (127.0.0.1) (00-00-00-00-00-00) (loopback: 1)
Sep 06, 2022 04:47:48.017 [0x7f12732761c0] DEBUG - * 3 eth0 (192.168.106.5) (00-11-32-CB-BB-59) (loopback: 0)
Sep 06, 2022 04:47:48.017 [0x7f12732761c0] DEBUG - * 4 eth1 (192.168.106.6) (00-11-32-CB-BB-5A) (loopback: 0)
Sep 06, 2022 04:47:48.017 [0x7f12732761c0] DEBUG - * 1 lo (::1) (00-00-00-00-00-00) (loopback: 1)
Sep 06, 2022 04:47:48.017 [0x7f12732761c0] DEBUG - Creating NetworkServices singleton.
The primary for the NAS is eth0 but PMS found eth1.
This will cause confusion.
Recommendation -
- Control Panel - Network - Network Interfaces
- Create a BOND adapter using both eth0 and eth1.
- Initially, youâll get 192.168.106.5 as the network address.
Manually change it if you need to. - Verify the new BOND adapter has a proper network gateway IP and DNS IP.
- Now restart Plex and refresh your browser & appsâ connections to the Syno.
This will get you started
Other option: Simply unplug one of the ethernet cables (the one you donât need)
What happens on these:
- DSM will flip-flip between both because, by TCP-IP rules, they are equal.
- PMS is favoring eth1 (it found that to be the primary because of DSMâs flip-flop.
- PMS sees this flip flop too and gets confused on the source & destination IP.
- It gets cautious and raises the error.
Let me know your progress.
Well you have a real gift! I bonded the network, restarted Plex and syno. Opened plexed and everything under the admin account was there!
Thank you so much! I think you need a new usernameâŠ! Something with wizard or warlord, something/one almighty and powerful! Because I can present an issue and you have a solution on how to fix it!
Anyways sorry,
And Very Big Thanks!
Hello,
I am having an issue with my Plex after I run it on Synology. I claimed the server, thatâs all fine but I cannot open Plex using that given URL from the NAS. It doesnât matter if I use http://ip-address:32400/web or http://ip-address:32400/manage or the same combination but with https instead, I just wonât get in
Is there any solution to this, please?
Please share more info / show a screenshot of what you do get ?
âI just wonât get inâ isnât very helpful.
Manually making a ZIP of the PMS Logs folder and attaching it is also very helpful.
How should I take PMS logs if I canât connect to the server?
Also, here is the version of my DSM - 7.1-42661 Update 4
Plex installed manually using the latest version PlexMediaServer-1.29.0.6209-9fa696df6-x86_64_DSM7.spk
When I want to open PMS from NAS it just says the site canât be reached.
The URL it gives me is http://192-168-1-18..direct.quickconnect.to:32400/web
- Stop Plex (if itâs running)
- Open FileStation
- Navigate: PlexMediaServer/AppData/Plex Media Server
- Right-click
LogsâCompress to Logs.zip - Download that ZIP file to your computer
- Upload here with your next reply
I see youâre using QuickConnect. Donât do that right now. Quick connect causes a LOT of problems when the machine isnât properly claimed.
Use the LAN IP only. http://LAN.IP.of.Syno:32400/web
^^ Try this first please
Hi @ChuckPa
have you checked the logs please?
Connecting to PMS using LAN IP does not work at all, the site cannot be reached
Logs.zip (2.0 MB)
PMS is configuring itself and is ready
Do not use the QuickConnect link.
Open it directly by LAN IP. http://192.168.1.18:32400/web
Sep 15, 2022 13:54:21.926 [0x7fa5535617c0] DEBUG - Detected primary interface: 192.168.1.18
Sep 15, 2022 13:54:21.926 [0x7fa5535617c0] DEBUG - Network interfaces:
Sep 15, 2022 13:54:21.926 [0x7fa5535617c0] DEBUG - * 1 lo (127.0.0.1) (00-00-00-00-00-00) (loopback: 1)
Sep 15, 2022 13:54:21.926 [0x7fa5535617c0] DEBUG - * 3 eth0 (192.168.1.18) (90-09-D0-10-C5-D5) (loopback: 0)
Sep 15, 2022 13:54:21.926 [0x7fa5535617c0] DEBUG - * 4 eth1 (169.254.126.226) (90-09-D0-10-C5-D6) (loopback: 0)
Sep 15, 2022 13:54:21.926 [0x7fa54d5c3b00] DEBUG - PublicAddressManager: Obtaining public IP.
Quick Connect cannot be used on DSM 7 until after the server is claimed.
To confirm, your computerâs IP address is 192.168.1.x ?
Yes, my PCâs IP address is 192.168.1.x and 192.168.1.18 is my NAS.
And it wonât open when I tried that IP address.
It worked perfectly fine for some time after I updated DSM from v6 to v7 and then it suddenly stopped working
QuickConnect is turned off
Please do the following:
- Restart PMS
- Let it run for 2 minutes
- While itâs starting up. Completely CLOSE the browser (all windows)
- After 2 minutes, Open a fresh browser
- Open an incognito window
- In that open window, http://192.168.1.18:32400/web
- It will report that the server isnât hosted by Plex â Yes, we know⊠itâs hosted on the NAS â hahah
- Now sign into Plex/web
- Stop Plex
- Open FileStation
- Navigate to: PlexMediaServer/AppData/Plex Media Server
- Right-click
LogsâCompress to Logs.zip - Download the ZIP file
- Attach here.
Please let me know how far you get with this step
Iâve done those steps but only get to number 5.
PMS wonât open in incognito when accessing that LAN IP
Here is the log
Logs.zip (640.4 KB)
Are you stating that you canât open PMS by LAN IP?
If you are â Turn off the Synology Firewall. Figure it out later.
Iâve confirmed the server is running and claimed to your email address and it is sitting there waiting
Sep 19, 2022 05:57:43.649 [0x7fd2bb0e57c0] DEBUG - Network interfaces:
Sep 19, 2022 05:57:43.649 [0x7fd2bb0e57c0] DEBUG - * 1 lo (127.0.0.1) (00-00-00-00-00-00) (loopback: 1)
Sep 19, 2022 05:57:43.649 [0x7fd2bb0e57c0] DEBUG - * 3 eth0 (192.168.1.18) (90-09-D0-10-C5-D5) (loopback: 0)
Sep 19, 2022 05:57:43.649 [0x7fd2bb0e57c0] DEBUG - * 4 eth1 (169.254.126.226) (90-09-D0-10-C5-D6) (loopback: 0)
Sep 19, 2022 05:57:43.649 [0x7fd2bb0e57c0] DEBUG - Creating NetworkServices singleton.
Yes, I canât open PMS by LAN IP.
It worked but then it stopped without me changing anything except DSM version upgrade but I canât confirm if it stopped working immediately after the update.
As you can see below, the firewall is disabled and I havenât enabled it yet.
I tried to turn off Windows firewall too, still the same result.
But I tried this:
PMS completely uninstalled + erased all files related to it
NAS rebooted
PMS installed from the package manager [beta]
PMS still wonât open using PMS shortcut or using LAN IP address
NAS has created Plex URL using quickconnect ID even though I turned quickconnect off, is that correct?
Thank you for that screenshot. You now confirm the problem.
You have PMS 1.21.0-3744 installed.
That was for the DSM 7 Beta only. Synology will not update it.
As consequence, it does not function correctly since DSM became final release.
This is why youâre seeing a QuickConnect link when none should be active.
You might have a mess on your hands at this point (given you had Plex on DSM 6 and now have this beta installed) but it can pretty easily be remedied once we establish which state your PMS installation is in.
Please confirm for me?
You still have your existing DSM 6 Plex server in the old âPlexâ shared folder ?
