The Case of the Missing Seasons & Episodes
Server Version#: Version 4.63.0
Player Version#: 7.24
I have added Miss Fisher’s Murder Mysteries 2012 - 2015 to my Plex
It has THREE seasons.
It was incorrectly identified as Ms Fisher’s Modern Mysteries, which only has two seasons.
I fixed the matching, but the rest of the missing seasons and episodes did not show up. I removed the folder, rescanned, cleaned the database, readded the folder and rescanned and it always stays the same. Restarting plex or my windows PC does not help at all. I have even removed the folder, emptied trash, cleaned the db, rescanned, restarted pc, readded folder, rescanned, but it is always the same.
The files are not damaged, and when I add them as my own video, without scanning the TVDB, it is all there, of course not labeled. When I re-add them back as TV Shows, the same problem occurs. The scanner knows something is wrong, here is a snippet from my scanner log file:
Oct 01, 2021 18:02:25.053 [21212] DEBUG - Scanner: Processing directory H:\PLEX\Series\Miss Fisher’s Murder Mysteries\Season 1 (parent: yes)
Oct 01, 2021 18:02:25.058 [21212] DEBUG - Directory had 13 files, database had 4 files, can’t skip.
Oct 01, 2021 18:02:25.082 [21212] DEBUG - Looking for path match for [H:\PLEX\Series\Miss Fisher’s Murder Mysteries\Season 1\Episode 10 - Death by Miss Adventure.mkv]
Oct 01, 2021 18:02:25.083 [21212] DEBUG - Path matched, we’re reusing media item 293362
Oct 01, 2021 18:02:25.083 [21212] DEBUG - Looking for path match for [H:\PLEX\Series\Miss Fisher’s Murder Mysteries\Season 1\Episode 11 - Blood & Circuses.mkv]
Oct 01, 2021 18:02:25.084 [21212] DEBUG - Path matched, we’re reusing media item 293363
Oct 01, 2021 18:02:25.085 [21212] DEBUG - Looking for path match for [H:\PLEX\Series\Miss Fisher’s Murder Mysteries\Season 1\Episode 12 - Murder in the Dark.mkv]
Oct 01, 2021 18:02:25.086 [21212] DEBUG - Path matched, we’re reusing media item 293364
Oct 01, 2021 18:02:25.086 [21212] DEBUG - Looking for path match for [H:\PLEX\Series\Miss Fisher’s Murder Mysteries\Season 1\Episode 13 - Murder on a Midsummer Night.mkv]
Oct 01, 2021 18:02:25.087 [21212] DEBUG - Path matched, we’re reusing media item 293365
Oct 01, 2021 18:02:25.087 [21212] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/?percentComplete=%2B0&subtitle=Miss%20Fisher’s%20Murder%20Mysteries%20-%20Season%201
Oct 01, 2021 18:02:25.088 [21212] DEBUG - HTTP/1.1 (0.0s) 200 response from PUT http://127.0.0.1:32400/activities/?percentComplete=%2B0&subtitle=Miss%20Fisher’s%20Murder%20Mysteries%20-%20Season%201 (reused)
Plex Media Server Logs_2021-10-01_18-37-47.zip (7.9 MB)
Please help!! :grin:
Follow the naming guide. Category : TV Show Files (Naming and Organizing) | Plex Support
to
H:\PLEX\Series\Miss Fisher’s Murder Mysteries (2012)\Season 1\Miss Fisher’s Murder Mysteries (2012) - S01E13 - Murder on a Midsummer Night.mkv
Did not work at all… Still exactly the same.
Plex Media Server Logs_2021-10-01_23-51-37.zip (7.4 MB)
Sorry. After you rename files, you must Plex Dance those files for your server to rematch the show. Otherwise, it just reuses matching information from before.
I’ve done this before I posted my problem here on plex. But I’ve done it again and the results are the same. Here’s my log files again after I did the plex dance.
Plex Media Server Logs_2021-10-03_06-50-00.zip (6.1 MB)
Oct 03, 2021 06:49:32.068 [7744] DEBUG - Looking for path match for [H:\PLEX\Series\Miss Fisher’s Murder Mysteries (2012)\Season 1\Miss Fisher’s Murder Mysteries (2012) - Episode 12 - Murder in the Dark.mkv]
Oct 03, 2021 06:49:32.082 [7744] DEBUG - Looking for path match for [H:\PLEX\Series\Miss Fisher’s Murder Mysteries (2012)\Season 1\Miss Fisher’s Murder Mysteries (2012) - Episode 13 - Murder on a Midsummer Night.mkv]
These are still named wrong.
Perfect!! I see the mistake! Thank you so much for helping me resolve this! Truly am grateful!
