TheTVDB V3 - Post grade issues
Give this a try
  • Shutdown PMS
  • Clear all the contents in Plex/Library/Application Support/Plex Media Server/Plug-in Support/Caches/*
  • Start PMS
  • Force Refresh All Metadata
Good to go! Thanks to all who sorted this out!
so, im sure it just me, but the metadata is loading great… my dvr functionality is messed up now…weird that I can only see what’s live and cant see the scheduled recordings any more. not sure what it is…just has to be a cooincedence…
Clearing the caches made mine work. Thanks everyone involved in fixing this!
Please discuss DVR-related issues in a DVR-tagged thread. :slight_smile:
The flavor of this soup is “TVDB” :smiley:
I can’t locate this path in Synology… Any pointers?
Think it should be here:
"/volume1/Plex/Library/Application Support/Plex Media Server/Plug-in Support/Caches"
Got it … Thanks! Wouldn’t it be sufficient just to delete
com.plexapp.agents.thetvdb
I’ve got quite a music library that is fine as is.
Control Panel - Shared Folders - EDIT the Plex share - Permissions tab
Give yourself permission to R/W
Open File Station.
You can now see the Plex share
That’s the only one I deleted
Even easier than SSH. Thanks Chuck!
Would this work if we’re using Nvidia shield as our Plex server
According to the release notes you will have to wait til Monday for the shield update.
Ok thanks , I’ve 300 shows and 0 posters for them and no metadata either hopefully this will fix it
Latest update (v1.18.2.2058) didn’t fix the issue here (binhex-plexpass Docker container on Unraid). Deleted the cache and started a full refresh. The SSL error is gone in the logs but has been replaced by another line:
INFO (__init__:1079) - Invalid header value '__cfduid=d4c3a889431af5ec830f56f5507f0d5191545377278\r'
None of the posters, season artwork or episode thumbnails are being downloaded. The full refresh was actually removing the posters I already had so I stopped the server to prevent it wiping all my posters out. Some artwork has been kept so hopefully it’s just a caching issue.
Plex Media Server Logs_2019-11-23_19-28-57.zip (6.6 MB)
Latest update (1.18.2.2058) working here for some shows, but not for all the shows.
Here is the log for one of the shows (TVDB id: 371791, title “ETA, el final del silencio” - 2019) not working well (poster is downloaded, but not episode thumbnails):
2019-11-22 18:55:23,475 (7f54e5ffb700) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.thetvdb/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMTAKczIKZXNzNApsYW5nYjFzNQpmb3JjZWIwczgKcGVyaW9kaWNzNgozMDU1NzdzNApkYmlkaTAKczcKdmVyc2lvbm5zMTAKcGFyZW50R1VJRG5zOApwYXJlbnRJRHM3ClRWX1Nob3dzMTAKbWVkaWFfdHlwZXM0Mwpjb20ucGxleGFwcC5hZ2VudHMudGhldHZkYjovLzM3MTc5MT9sYW5nPWVzczQKZ3VpZHM2CjM3MTc5MXMyCmlkcjAK
2019-11-22 18:55:23,476 (7f54e5ffb700) :  DEBUG (runtime:49) - Received packed state data (556 bytes)
2019-11-22 18:55:23,477 (7f54e5ffb700) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.thetvdb/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMTAKczIKZXNzNApsYW5nYjFzNQpmb3JjZWIwczgKcGVyaW9kaWNzNgozMDU1NzdzNApkYmlkaTAKczcKdmVyc2lvbm5zMTAKcGFyZW50R1VJRG5zOApwYXJlbnRJRHM3ClRWX1Nob3dzMTAKbWVkaWFfdHlwZXM0Mwpjb20ucGxleGFwcC5hZ2VudHMudGhldHZkYjovLzM3MTc5MT9sYW5nPWVzczQKZ3VpZHM2CjM3MTc5MXMyCmlkcjAK
2019-11-22 18:55:23,477 (7f54e5ffb700) :  DEBUG (model:32) - Loading model with GUID com.plexapp.agents.thetvdb://371791?lang=es
2019-11-22 18:55:23,477 (7f54e5ffb700) :  DEBUG (model:234) - Deserializing from /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Metadata/TV Shows/5/396c18beb21998c7c4439cb261275e0a7b39e54.bundle/Contents/com.plexapp.agents.thetvdb/Info.xml
2019-11-22 18:55:23,480 (7f54e5ffb700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/library/metadata/305577/tree'
2019-11-22 18:55:23,483 (7f54e5ffb700) :  INFO (__init__:780) - def update()
2019-11-22 18:55:23,484 (7f54e5ffb700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/series/371791?lang=es'
2019-11-22 18:55:23,819 (7f54e5ffb700) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/services/tmdb?uri=%2Ffind%2F371791%3Fexternal_source%3Dtvdb_id'
2019-11-22 18:55:25,933 (7f54e5ffb700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/series/371791/actors'
2019-11-22 18:55:26,280 (7f54e5ffb700) :  DEBUG (networking:143) - Requesting 'https://meta.plex.tv/tv_e/371791/eta+el+final+del+silencio/2019'
2019-11-22 18:55:26,409 (7f54e5ffb700) :  ERROR (networking:196) - Error opening URL 'https://meta.plex.tv/tv_e/371791/eta+el+final+del+silencio/2019'
2019-11-22 18:55:26,410 (7f54e5ffb700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/series/371791/episodes?page=1'
2019-11-22 18:55:26,744 (7f54e5ffb700) :  INFO (__init__:898) - Show ordering is: aired
2019-11-22 18:55:26,745 (7f54e5ffb700) :  INFO (__init__:926) - No media for season 1 episode 4 - skipping population of episode data
2019-11-22 18:55:26,746 (7f54e5ffb700) :  INFO (__init__:926) - No media for season 1 episode 5 - skipping population of episode data
2019-11-22 18:55:26,746 (7f54e5ffb700) :  INFO (__init__:926) - No media for season 1 episode 6 - skipping population of episode data
2019-11-22 18:55:26,747 (7f54e5ffb700) :  DEBUG (threadkit:234) - Starting a parallel task set named UpdateEpisodes with 3 tasks
2019-11-22 18:55:26,748 (7f54e4ff9700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/episodes/7434469?lang=es'
2019-11-22 18:55:26,749 (7f54c37c8700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/episodes/7434468?lang=es'
2019-11-22 18:55:26,763 (7f54c27c6700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/episodes/7436707?lang=es'
2019-11-22 18:55:27,066 (7f54c37c8700) :  INFO (__init__:1022) - Season Extra XML is empty - therefore, no episode XML
2019-11-22 18:55:27,066 (7f54e4ff9700) :  INFO (__init__:1022) - Season Extra XML is empty - therefore, no episode XML
2019-11-22 18:55:27,075 (7f54c27c6700) :  INFO (__init__:1022) - Season Extra XML is empty - therefore, no episode XML
2019-11-22 18:55:27,076 (7f54e5ffb700) :  DEBUG (threadkit:244) - Parallel task set UpdateEpisodes ended
2019-11-22 18:55:27,077 (7f54e5ffb700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/series/371791/images?lang=es'
2019-11-22 18:55:27,385 (7f54e5ffb700) :  ERROR (networking:196) - Error opening URL 'https://tvdb2.plex.tv/series/371791/images?lang=es'
2019-11-22 18:55:27,386 (7f54e5ffb700) :  INFO (__init__:162) - HTTPError 404:
2019-11-22 18:55:27,387 (7f54e5ffb700) :  INFO (__init__:684) - Bad image type data for TVDB id: 371791
2019-11-22 18:55:27,391 (7f54e5ffb700) :  DEBUG (networking:138) - Fetching 'https://tvdb2.plex.tv/series/371791/images?lang=en' from the HTTP cache
2019-11-22 18:55:27,395 (7f54e5ffb700) :  DEBUG (networking:138) - Fetching 'https://tvdb2.plex.tv/series/371791/images/query?keyType=poster&lang=en' from the HTTP cache
2019-11-22 18:55:27,397 (7f54e5ffb700) :  DEBUG (networking:138) - Fetching 'https://tvdb2.plex.tv/series/371791/images/query?keyType=season&lang=en' from the HTTP cache
2019-11-22 18:55:27,398 (7f54e5ffb700) :  DEBUG (threadkit:234) - Starting a parallel task set named DownloadImages with 2 tasks
2019-11-22 18:55:27,399 (7f54e5ffb700) :  DEBUG (threadkit:244) - Parallel task set DownloadImages ended
2019-11-22 18:55:27,399 (7f54e5ffb700) :  INFO (__init__:1115) - Series Extra XML is empty - therefore, no season XML
2019-11-22 18:55:27,403 (7f54e5ffb700) :  DEBUG (model:229) - Serializing to /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Metadata/TV Shows/5/396c18beb21998c7c4439cb261275e0a7b39e54.bundle/Contents/com.plexapp.agents.thetvdb/Info.xml
2019-11-22 18:55:27,403 (7f54e5ffb700) :  DEBUG (runtime:88) - Sending packed state data (583 bytes)
2019-11-22 18:55:27,404 (7f54e5ffb700) :  DEBUG (runtime:924) - Response: [200] str, 16 bytes
Hope it helps!
Hello All,
I was having a similar issue with two newer shows not updating posters etc whatever I did. I followed the advice above:
stopped service
deleted com.plexapp.agents.thetvdb under Plex/Library/Application Support/Plex Media Server/Plug-in Support/Caches
restarted server
refreshed metadata for the two shows with issues
resolved
Thnkas ChuckPA and everyone else for your help. This was driving me nuts :slight_smile:
Thanks @talonsco, but I’ve already done these steps several times, but episode thumbnails for this show are still not downloaded.
You might be running into the access denied issue with artwork on TVDB. Have you tried manually viewing the artwork on the site and see if it loads? I’ve been seeing instances where you can see the thumbnail version fine but if you try and view the full version it doesn’t work.
For example trying to open any of the season posters here -
https://thetvdb.com/series/rick-and-morty/seasons/official/4
I think you are on to something here as it relates to season posters. I tried to change a few season posters to ones different than the default and the result was a blank image/box. The ones that can be viewed full size on TVDB do pull in and update the season poster in Plex, the ones that return an error of “The requested content cannot be loaded” result in a blank poster in Plex.
