I am adding poster art for TV series..
example:
Walking Dead (2010)
Walking Dead (2010).png (poster art)
season 01
season 02
etc…
I am putting the Walking Dead (2010).png file under the Walking Dead (2010) root folder
I do the plex dance and it does not show up am I missing something?
I do have local assets checked.. I have title cards added with no issues, but poster art is the issue
Name the show’s poster show, poster or folder. Then refresh the show’s metadata (no need to do a Plex Dance).
ok I did poster.png… not showing
did Walking Dead (2010) - poster.png… not showing
ideas??
Once you have edited the show and selected one of the posters on offer manually, this manual selection “sticks”.
But you will find the version you have placed inside the show folder among the posters to select from (after refreshing metadata).
It is just a bit difficult to know which one it is – unless it is a different motive than all the other ones. (Hint: it might be one of the last or even the last one, if you added it after the show has been matched.)
