TV Show isn't sorting correctly...
I’m trying to get multiple series of the Power Rangers to display correctly but I’ve been having difficulty. I had them all named in order of season but Plex wouldn’t sort them correctly. I tried changing the naming and listing them as S01 for each respective entry in the series but that didn’t work either. Anyone have any ideas for getting them to list properly in Plex?
Power Rangers
http://thetvdb.com/index.php?tab=series&id=72553&lid=7
  1. Look up your show on TheTVDB
  2. Take the title as it is used on TheTVDB. If there is something in parentheses, take that too. If the title contains invalid characters (depends on your file system), like § : % *, simply leave them out.
  3. Check the naming and the folder structure of your show. Name the top folder of the show exactly after the title on TheTVDB. No abbreviations. No additional subfolders. No aliases.
  4. Name the episode files according to the above linked naming guide. Use the same title as for the top folder. Show's Title - s01e01 - additional info.ext (’- additional info’ can be left out)
  5. After you corrected the naming and folder structure, perform the Plex Dance with all files for this show.
Correcting file naming for a whole tv show is convenient and quick with Filebot.
I’ll give that a try, thank you
