Server Version#:1.40.2.8395
Player Version#: N/A
Metadata coming from tvdb dvd doesn’t seem to match what’s on the site for Bluey Season 2. The plex dance has been done and the files are following the naming conventions. Am I doing something incorrectly or is this a bug? Pictures of the problems are attached.
What episode order did you configure for that library (or this particular show)?
The library ordering is set to TheTVDB and the episode sorting is set to oldest first. The show has episode ordering set to TheTVDB (DVD) and episode sorting to Library default.
It looks like there were changes not to long ago on TVDB and we did not pick them up. I’m gonna ask that show be refreshed manually to see if that fixes it but that may take a day or two.
I don’t know that show well but aired and DVD order on TVDB seem to be the same as TMDB https://www.themoviedb.org/tv/82728-bluey/season/2 (of course I may be missing something)
Thanks, I’ll do another plex dance towards the end of the week then. There are episode order differences in other seasons between the air order and dvd order. Does TMDB sorting support dvd ordering?
No, just a quick glance on their site it seem to be the same but i did not take a particularly close look to compare
What does this mean exactly?
I don’t know how to make that more clear.
TVDB has data
We grab that data and have regular scripts to update regularly
Sometimes thing don’t update correctly
You just did.
Thanks for the clarification. I wasn’t sure what “pick them up” meant for sure.
I tried another plex dance today and it seems all issues are sorted. Thanks for your help with this!
