PMS not fetching correct metadata from TVDB or TMDB for a TV Show
Server Version#: Version 1.42.1.10060
Player Version#: Version 4.149.0
My Issue is similar to the below issue and the TV show requires manual refresh from Plex’s end :
My Problem:
There is a show named Make A Wish (2021) having TMDB ID: 128698 and TVDB ID: 405881 . It is showing the correct poster image for the show but the description, studio and cast and other information is coming from a show named Make A Wish (1971).
Please see the below screenshots from what I am getting when i do fix match for the show and search “tvdb-405881”:
This is the cast member plex is fetching:
This is the screenshot from tvdb website for this particular show:
This is the cast members screenshot from tvdb:
Do you have your library set to themoviedb or tvdb by default?
It’s set to TVDB by default. But that’s not the problem, as you can see in the screenshots when i search for the show with tvdb id the summary that it is fetching for the show the dialog box is not the same as the one actually on the tvdb page. It’s showing summary and cast of another show of the same name which aired in 1971. But, the poster it’s showing is of the correct show.
