Synology DSM Version - 7.01-42218
Plex Version - 1.25.3.5409-7000
I’m unable to add movies to Plex from my server. When I create a library and assign it a folder on the NAS, the library doesn’t add the files from the folder.
Could be for a number of reasons – with the little information we can mostly only guess.
The most common/obvious cause appear to be a permission issue. Make sure the system user for the Plex Media Server on your Syno has access to the library folder.
Otherwise… here’s a list of potential reasons why Plex might ignore your files:
I checked the permissions, and plex has read/write permission.
You’re on DSM7… so make sure the user which has access is actually PlexMediaServer – not plex.
Thanks Tom. How do I do that? When I check permissions, PlexMediaServer doesn’t show up. I tried to create one named “PlexMediaServer”, but it’s not letting me.
Here you go
A post was split to a new topic: Problems accessing PMS on DSM 7
