Weird matching with partial similar show name
There’s a show named ‘YOU’. There’s also a show named ‘You’re the Worst’
When I add YOU/Season 1/you.s01e01.mkv it gets picked up as You’re the Worst/Season 1/you.s01e01.mkv
Is it the ‘’’ in You’re the Worst? How can I get YOU to show up and not match to you’re the worst?
Add the release year in parentheses to the show title.
Whenever there’s trouble with matching, stick as close as possible to the recommended naming schema.
YOU (2018)/Season 01/you - s01e01.mkv
After renaming the files and folders, perform the Plex Dance:
Thank you, that fixed it.
