why bridge mode? that means you’re relying on the ISP to assign your local IP addresses, doesn’t it? except you have an actual 2nd router which covers that function…
can you assign a single port (or 32400-32400) and make this TCP only? shouldn’t make a difference but it’s worth a shot. also… to rule out some stupid mishap, let’s assign some entirely different external port (e.g. 39123)
any firewalls on this remote desktop of yours which could interfere?
do I interpret that correctly as “but it’s still not working”?
what happens if you misuse a more regular port such as 80 or 8080? (trying to rule out that your provider is blocking ports)
just disabled and enabled it 3 times, and on the 3rd time it decided to start working…
Seems like its something with the Plex application then.
Last screenshot are the current settings.
Get a copy of MiniWeb and spin it up, I think it listens on 8080 or 8888 by default, and browse to http://192.168.1.11:xxxx where xxxx is the port it uses either 8888 or 8080.
After you get the default blue web page go to your nighthawk and forward that same port again either 8888 or 8080 whatever is its default.
Go to canyouseeme.org and test that port and see if you get success.
Once you can get that working we can get the plex port setup.
