1 out of 600+ movies will not import into Plex...help!
Server Version#: 1.30.0.6486-7000
Player Version#: 1.60.1.3413-533a7645
Running Plex on Synology.
For the life of me, I cannot see why this movie will not import.
My movies always import and any issues I have had in past are typically due to a mismatch in year from TMDB. For example: “the gods must be crazy” 1980 or 1984 depending on where released.
In this case, Jurassic World Dominion (2022) everything lines up.
I have all movies in \Movies\Movie Title (Year)\Movie Title (Year) - source-resolution.filetype
In this case: \Movies\Jurassic World Dominion (2022)\Jurassic World Dominion (2022) - Bluray-1080p.mkv
…but Plex refuses to see it.
How to troubleshoot this and/or any suggestions?
standard steps:
  1. verify permissions for the file are ok
  2. display the library By Folder and check what item you find in the Jurassic World Dominion (2022) folder
  3. check your library for Duplicates (via filter) to see if it got merged with another movie
  4. sort the library by Date Added and check if it’s been matched as some other movie
It’s usually a good idea to place all the technical blah blah in 1 set of square brackets for Plex to ignore that information – though I don’t think this has anything to do with your particular issue.
If none of the above show any sign of your movie, you might need to dig a bit in your server logs.
If I may add?
of the few I have, this is how I have them
[chuck@lizum uhd.2009]$ ll Jurassic*
Jurassic Park (1993):
total 51959208
drwxr-xr-x   2 chuck chuck          46 May  9  2021 ./
drwxr-xr-x 299 chuck chuck       16384 Jan  1 15:07 ../
-rw-r--r--   1 chuck chuck 53206206325 May  9  2021 Jurassic Park (1993).mkv
Jurassic Park 3 (2001):
total 53150424
drwxr-xr-x   2 chuck chuck          48 May  9  2021 ./
-rw-r--r--   1 chuck chuck 54426009755 May  9  2021 Jurassic Park 3 (2001).mkv
Jurassic World (2015):
total 52580692
drwxr-xr-x   3 chuck chuck          65 Nov 21  2021 ./
drwxr-xr-x   2 chuck chuck        4096 Sep  2  2018 Extras/
-rw-r--r--   1 chuck chuck 53842602954 May  9  2021 Jurassic World (2015).mkv
Jurassic World Dominion (2022):
total 67758672
drwxrwxr-x   2 chuck chuck          56 Sep  7 16:14 ./
-rw-rw-rw-   1 chuck chuck 69384856219 Sep  3 20:49 Jurassic World Dominion (2022).mkv
Jurassic World Fallen Kingdom (2018):
total 50425484
drwxr-xr-x   2 chuck chuck          62 May  9  2021 ./
-rw-r--r--   1 chuck chuck 51635671207 May  9  2021 Jurassic World Fallen Kingdom (2018).mkv
[chuck@lizum uhd.2010]$
Thank you for quick reply.
It was #1.
I don’t know why, but the permissions in Synology for this file (not the folder) was missing one usergroup. Very strange.
If anyone has ideas how to troubleshoot why that happened I would be grateful!
Permissions on Synology can be weird.
Folder permissions can be fine but the file permissions underneath (specifically the ACLs) can be messed up.
I recommend scrolling down through here (Syno FAQ).
Near the bottom I show about granting permissions on the DSM side.
Thanks very much!
