With the announcement of the phasing out of HTPC support next year, will I still be able to use it as a server and send hundreds of tv series and hundreds of movies to my smart tv, phone and remote desktop PC? And continue to add new movies and TV series too?
What is being LOSYT with the drop of HTPC support?
itâs just an App/Client change. Nothing more. The server side of things remains the same.
What is being lost is the âTV Viewâ from Plex Media Player (being phased out in January of 2020 but will continually be updated until then), and the Plex App from the Windows store (which has been defunct for a while now apparently).
Itâs nothing anyone really needs to worry about, other than those who were using a Home Theater PC setup (where the TV is the primary display source from a PC attached to it playing the role of an HTPC, which is not most people).
I read that support article about migrating to another PC
Is another scenario with hundreds of movies and TV series to just let the new install of plex build and index new libraries from the existing hard drives ( 10 tb) moved to the new pc? Which option is more practical?
The approach described in the support article will keep your server configuration, libraries, (edited) metadata, collections, watch statusâŠ
Your approach means youâll start from scratch.
Yes, it will.
That being said⊠personally Iâd try to stick with the instructions from the support article. If your file names didnât allow Plex to match your media perfectly the first time youâll have to go through the same âvalley of tearsâ again (e.g. identifying and fixing all missing/incorrect matches, adding collectionsâŠ). Also I like to keep some of my watch history
The Day The Earth Stood Still (1950)
The Day The Earth Stood Still (2000)
for both movies, and for tv shows, you should always specify the (year) in the folder/filename.
this will help avoid issues with duplicate movies.
of course that may not help if a movie name is used for 2 different movies in the same year, someone recently posted an example of that, not sure what was the solution there except for âfix matchâ.
Movies
The Day The Earth Stood Still (1951)
The Day The Earth Stood Still (1951).ext
The Day The Earth Stood Still (2008)
The Day The Earth Stood Still (2008).ext
or
Movies
Love Plex ! My library is just growing and growing and growing !
Handbrake working 24 hours a day in some cases converting huge movie files into mkv format
Just wish there were and export/Import settings option which made transition to a new PC build seamless without having to go into hidden files and copy that folder to overwrite an existing one on a new install.
