Server Version: newest
Player Version: newest on all plattforms
Hello!
I have a big problem with the default languages in Plex regardless of device (web player, desktop version, ios, fire tv…)
In my Profile the default language for Audio is german (as can be seen in the picture).
All movies and shows in the library are in german and english. both audio streams are correctly identified.
Despite setting the default language to german, english is set by plex as default for every movie
and tv show. its not a problem of me manually changing it, it defaults to english for every new movie/show as well.
tried every setting and changing it back to english and german again, but the default audio is always english, have to manually change it to german.
I have the same issue and just wanted to ask to and found your thread already…
My server is a Synology one and all is set up like it should.
I even set my entire Synology server from english to german just to test but still same issue, everywhere set as german audio and the series are started in english and I have to switch manually to german…
I was able to fix this by logging into the plex website and setting my default in those properties. I’ve I set it to english in the plex server settings it would revert to something else after save and re-open.
I have the exact same problem, seems to be related to direct play
Not a problem when remuxing a movie
For my main account et my first guest account I had no problem, but for the two more accounts that i’ve added afterwards every movie track is defaulted to english (whereas everything is set to french in settings)
The “temporary” fix is to go back to an older Plex media server version (like v1.16.xx), login with plex web to the user session then updating to the latest Plex media server version
Going back to an old version on a NAS is not the solution…
There are now 4-5 new versions I upgraded too and still this bug isn’t solved yet
Hope this will be done soon…
I have the same problem but “only” for local users different from the admin user. For the admin all settings work like a charm. Now, my wife uses my account to avoid changing the language for every tv-show episode manually. But this can not be the final solution?!
I have the EXACT same problem, all my users have FRENCH to their profile, but the movie start in english. I created a new test account for testing purpose, SAME bug, what the hell. It drive my crazy … I imagine Plex won’t fix that, like hundred of major bugs.
EDIT: Ok guys, I just opened the database and guess what happen when you change your prefered audio track? NOTHING! lol I have updated the audio track to DEUTCH on my test account and the database KEEP the value to EN. What the hell?
