Cant connect to Plex outside local network
no because im using a update from year ago and never had issues
well that was my best guess… as for the router thing…hmmm
how would it affect if all my connections are local and still have the issue?
local meaning same city
i just tracert like u said US getting timeouts. chking a few more
local means on your own LAN… if you’re going across the internet at all that’s not local
Local / LAN == INSIDE your modem/router
Remote / WAN == OUTSIDE your modem/router
i was trying to clear that up i mean if its not going outside my isp would it still be using a edge router
Try tracing some hosts/IP addresses in your own country
hey chuck i time out on US Sites
i see frontier up there… i am also with them…connection???
or coincidence??
@mweste
But you’re talking to me.
I go from here to the backbone to discourse (forum).
You do the same to your local discourse
[chuck@lizum tmp.2017]$ nslookup forums.plex.tv
Server:		127.0.0.53
Address:	127.0.0.53#53
Non-authoritative answer:
forums.plex.tv	canonical name = plex.hosted-by-discourse.com.
Address: 64.71.144.207
Address: 2602:fd3f:3:ff01::cf
[chuck@lizum tmp.2018]$
lets ask others
with logs are service provided same so far chuck
does having multi server trigger this throttle. do i have to go through jersey again to the cold to take server back
check your PM
It’s almost 3am EST US.
That means Europe is waking up / getting to work.
I’m going to ping the guys as they come online.
internet provider name
in your opinion chuck do you think our servers caused this .
At this point, I don’t have ANYTHING definitive.
  1. I find it extremely unlikely for you all to BREAK your servers at the same time and only impact Remote Access
  2. I cannot explain why I am able to connect and stream from a server in Florida when others cannot from Florida servers.
This is a 2+2=3 situation.
We’re missing something important
Relax… I’m on a different provider and I’ve been able to traceroute from various different origins and looking glass sites to plex.direct without issue but I’m also still having this RA issue. If this is related to routing it’s likely a lower level than we are going to figure out here.
@bblboy54 BGP mess up?
