Can't mount library
Hi.
I upgraded DSM to version 7.0.1 on synology NAS. I struggled a bit with reloading Plex.
Now I have it there again, version 1.25.8.5663, but I can’t mount the original library.
I choose to add a library, I choose Movies. Next, I select the path to the files according to the menu, but it only goes to the main folder “Volume1” and then to “Cinema”. I will no longer set the path to the “Movies” folder. After saving = creating a library, of course when I request “search the library” the plex will not find anything.
In the NAS settings, I have read / write enabled for the plex.
I don’t know what I’m doing wrong anymore.
Will you please advise
Update: After clicking on the “cinema” path when setting up the library, the “cinema” folder looks empty.
At the same time, the files are well visible on the NAS.
@Vilibald
Did you refer to the DSM 7 section of the Synology FAQ ?
It seems you might have upgraded to DSM 7 without knowledge of all the changes DSM 7 caused.
Now OK, thx
