Cant resolve issue 320p library access friends
Server Version#:1.41.0.2876-e960c9ca
i can provide debug logs, but i really want to solve this issue
1 - computer is connected hard wired lan
2- my stream is fine in my network
3 all my friends are getting 320p resolution, and cant fix, i suspect they are on relay because i need to do port forward?
in my remote access i removed the check box and now it says
Not available outside your network
Your server is signed in to Plex, but is not reachable from outside your network
should i check the box and specify port? but it doesnt solve the issue as they sill only get 320p
i guess what i want to is solve this for once and for all so it plays at max quality for anyone streaming my content
Yes
You are essentially telling Plex to route your stream through a port that isn’t open
You need to do two things in the router. Give your server machine a static ip address so it doesn’t change and configure port forwarding
You may have to google how to do that on your specific router
You can pour over this trouble shooting guide
You can provide screen shots of your router settings with specific questions if you need assistance
hey your amazing, thanks for helping, so i spoke to isp, i went through my EERO app which is the router and i assigned a static IP, so that is done i set the static ip to the DESKTOP computer that has the plex. so now it says:Fully accessible outside your network
BUT my remote access keeps going into the red in the settings, i clicked manually specify post and i can use any number here or does it have to be a specific port number?
also
under the ip it shows a private ip ( this is the static ip i set ) and what is the public ip for?
The public IP should be the WAN IP address of your router – that’s the IP address of your router to the outside world.
Use that option if you have created a manual port forward on your router.
That’s a feature of many routers that allows requests to that public port from the outside to be passed on to a specific device in your home network.
As a reference… consider router to be a post office that’s linked to a specific zip code (=your router’s public IP address). Consider your port forward to be a post office mailbox – by (a) having one and (b) giving the mailbox number to somebody, they can directly address that mailbox to get their letter to you.
The port forward in your router should look something like this. This is a secondary step from assigning a static ip address
The internal ip is the ip of your Windows machine with the server
To keep things simple just use port 32400 for the internal and external port
32400 is what you put in the “manually specified public port” inside of the Plex settings
so either way i need to click the manual assign ok ill try but im still geting 320p when i do this.
Do you have a manual port forward in your router and are you pointing Plex to that port (via the Manually specify public port option)?
thanks so how how do change the WAN Ip, i see the private one as my static one. i understand what you are explaining i just dont know how to make it work. basically the public and the private ip are different,. all i want is for anyone using my library to get full resolution is there any other steps im missing or anything else i can show you to solve this?
yes sir i checked the box now and it says 32400 and the green says Fully accessible outside your network
i thought it would fix the issue but when i went down to the tv is set to 320p and when i select play orginal quality it keeps reverting back to 320 im assuming cause its using relay?
you don’t have to assume – while playing the video on your TV, check for the Now Playing tile on your server’s dashboard. If expanded, each playback should display if the stream is Local, Remote or Indirect (=using a relay).
Exemplary screenshot from the "now playing" section
https://support.plex.tv/articles/200871837-status-and-dashboard/
As for your public IP – you cannot change that and you don’t have to… it’s assigned to your router by the ISP. You can only assign / reserve IPs inside your home network.
If you’re having trouble with the remote access setup – there’s a few important checks:
  1. Does the public IP recognized by Plex (as displayed in the remote access settings) match the public IP address of your router?
  2. Is the public IP address of your router a publicly routable IPv4 address? – if you’re not sure what that means, you can paste the first two segments of the public IP (e.g. if the public IP is listed as 234.12.25.19 you could share 234.12.xxx.xxx)
  3. Verify in your router settings if there’s actually a manual port forward… for simplicity, use a port other than 32400 – e.g. 33400 – can you see the published port from outside your home network? – you can check that e.g. using a service like canyouseeme.org
There’s more checks in “The Basics of Remote Access Troubleshooting” post linked by JaysPlex7 – but lets start with the 3 above.
what transmission protocol does the transmission use or use auto?
Are you asking about creating a port forward? – that requires a tcp port (udp isn’t needed).
right now im on phone with isp, they just set it to tcp and udp now they reset to just tcp port forward, and they opened the port i provided, but im still getting 320p
Can you see/access the specified public IP on your router from outside your home network?
i checked and noit doenst maybe its ESET firewall?
Firewall could be blocking your content/accessibility – temporarily disabling it and re-testing your connection should confirm/eliminate that.
If you’re on it… what network profile have you assigned to your Windows setup (private or public)? Setting it to public can be problematic because that’ll make Windows prevent/block certain communication too.
If you cannot even see the public port from your port forward from outside your home network, that usually implies there’s something wrong / blocking between “the internet” and your router (incl. that endpoint, e.g. a bad port forward configuration).
so i did check and no it says it doenst see it, my isp opened the port, and i have static ip. still says this Error: I could not see your service on ip etc…
im thinking maybe eset firewall? thanks for helping, its been an issue for a while so now decided its time to fix for once and for all
Tom so I’ve done all my last checks and based on what I’m seeing people can access, so I have basically four people in my family accessing my server two of them are able to get everything in the original resolution and the three others can only see 320 P
So I guess my main question here is this a problem coming from my end or is it a problem on there side? Where can they change the quality settings because they’ve tried to put it at maximum and it keeps reverting back to 320
But I have three other people who are seeing everything in full resolution, so I’m really confused here not sure what to do
Have you also checked if their streams from your server are showing as Remote or Indirect on your server’s Now Playing section?
And two new questions:
  1. what’s the internet upload speed you get from your ISP?
  2. have you applied any restrictions for your remote access / remote streams? – specifically… Settings > [Server Name] > Remote Access > Limit remote stream bitrate
